erik98225 Posted May 31, 2004 Report Posted May 31, 2004 I have a 97 Cutlass Supreme 4 door, which uses the 9006 bulbs (low beam headlights) for DRL. Is there any way to disable DRL but retain the "automatic lights on at night" feature? Yes I am willing to cut/splice wires, etc. if that is what it takes. Forgive me, but I HATE daytime running lights! Erik Quote
sl3196 Posted May 31, 2004 Report Posted May 31, 2004 Should be a fuse you can pull. My 96 had one inside. I think it is the DRL fuse. Quote
erik98225 Posted May 31, 2004 Author Report Posted May 31, 2004 Should be a fuse you can pull. My 96 had one inside. I think it is the DRL fuse. I've tried pulling that fuse before, but it disables the whole light sensor circuit so you HAVE to use the switch. That's what I didn't want. Instead, I read on this site a better way to do it. I left the DRL fuse connected, and unplugged the big heatsink-looking thing that lowers the voltage to the headlights in the daytime. Took all of 5 minutes. Now the lights work like they should. Always on at night, and if you want them in the daytime, you use the switch. Problem solved. 8) Quote
sl3196 Posted June 1, 2004 Report Posted June 1, 2004 Oh yeah I forgot the fuse turned off auto lights. Mine was way to sensitive so they were almost always on. Quote
