Heza Posted May 28, 2004 Report Posted May 28, 2004 so i just got the lower intake off of my girlfriend's '94 3100 in my old GP and will need to remove/move out of the way the pushrods to pull the intake gaskets out. question is...are the rocker arms variable or fixed? what i mean is, do they just torque down to a certain spec or are they adjustable? thanks for any help!! Quote
Guest Anonymous Posted May 28, 2004 Report Posted May 28, 2004 Not adjustable. They get torqued. Quote
Heza Posted May 29, 2004 Author Report Posted May 29, 2004 thats what i thought, but just making sure. thanks! Quote
Guest Anonymous Posted May 29, 2004 Report Posted May 29, 2004 Yeah, what the assmonkey said. :shock: Quote
Heza Posted May 29, 2004 Author Report Posted May 29, 2004 ok...just to make sure...in the '94 service manual there are two sections for the rocker arms. a) standard non-adjustable rocker arms adjustable rocker arms why have two sections if they are standard? what has adjustable rocker arms per the '94 Grand Prix service manual? Quote
Guest Anonymous Posted May 29, 2004 Report Posted May 29, 2004 Maybe the roller rockers are adjustable. I can't see stamped rockers being adj. though. Quote
god910 Posted May 29, 2004 Report Posted May 29, 2004 Yeah, what the assmonkey said. :shock: Your avatar. Monkey, w/ it ass a' shakin. Henceforth, assmonkey. Quote
Heza Posted May 29, 2004 Author Report Posted May 29, 2004 Maybe the roller rockers are adjustable. I can't see stamped rockers being adj. though. how can i differentiate between them? i really dont want to get into adjusting adjustable rockers. the service manual makes it look like a shitty task. Quote
Guest Anonymous Posted May 29, 2004 Report Posted May 29, 2004 Rollers will look like machined pieces put together. And stamped will look like just that, one piece of stamped steel. I may have a pic of my 94 3100 heads. Quote
Guest Anonymous Posted May 29, 2004 Report Posted May 29, 2004 Here are different types of rollers. http://images.google.com/images?q=roller+rockers&ie=UTF-8&hl=en This is a stamped rocker. http://www.jegs.com/photos/2701180016.jpg Quote
Brian P Posted May 29, 2004 Report Posted May 29, 2004 they are all non-adjustable. The procedure is there just in case a dealer switches to an adjustable setup for whatever godly reason. Quote
Heza Posted May 29, 2004 Author Report Posted May 29, 2004 thanks for the help on the subject. just to make sure though before i start working on it after an Honor Guard funeral today: Quote
Guest Anonymous Posted May 29, 2004 Report Posted May 29, 2004 Those are stamped. Just torque them. Do you have the torque specs? Quote
Heza Posted May 29, 2004 Author Report Posted May 29, 2004 Those are stamped. Just torque them. Do you have the torque specs? yup, 18 ft/lbs. thanks! can finish this project tonight! another question...what would you explain brown semi-slippery residue in the coolant track as being? theres a film in the heads and in any orifice where coolant flows. i will be flushing the system regardless, but curious. it uses the green anti-freeze and was flushed last year. Quote
Heza Posted May 30, 2004 Author Report Posted May 30, 2004 ooh I see stamped performance!! ill have an excellent picture write up of changing lower intake gaskets on the 3100...let me tell you. Quote
Brian P Posted May 30, 2004 Report Posted May 30, 2004 I'm next, I'm sure I am. But Ive done it 100x yet. I just want to use the revised gasket Quote
Robby1870 Posted May 30, 2004 Report Posted May 30, 2004 I'm next, I'm sure I am. But Ive done it 100x yet. I just want to use the revised gasket maybe you'll get REAL lucky and find slots for the roller rockers......1.6 roller biotch! Quote
Heza Posted May 30, 2004 Author Report Posted May 30, 2004 I'm next, I'm sure I am. But Ive done it 100x yet. I just want to use the revised gasket revised gasket, pish posh. what was leaking on my car was that damn sealant bead where the block mates to the lower intake. Quote
Brian P Posted May 30, 2004 Report Posted May 30, 2004 Oh, you're lucky. The gaskets normally crack, separate and break off at the coolant port (inner side) 100% failure rate for the old ones, eventually... Quote
Heza Posted May 30, 2004 Author Report Posted May 30, 2004 all this and i cannot get the damn oil pump drive out to start my rebuild. Quote
Guest Anonymous Posted May 30, 2004 Report Posted May 30, 2004 Channelocks, twist while pulling up. Quote
Heza Posted May 31, 2004 Author Report Posted May 31, 2004 Channelocks, twist while pulling up. yup, this morning i went and got some and it popped it right out. the o-ring wasnt rock hard, but the exterior surface was pretty tough. still had a little flex in it. i have so many pictures of my project and once i find enough webspace to host my pictures, i will make a full all out write up of replacing the lower intake. Quote
