Cutting HUD Dash Hole
The car I got my HUD unit out of had no dash top on it so I don't know where exactally to cut the hole. Does anyone know the measurements or have a "stencil" to cut it? I'm assuming if the hole is not in the right spot it will not be able to reflect onto my windshield.
Guest Anonymous
what year is your car? Let me know and i will find out and car make you a template.
Guest Anonymous
I think the 93 HUD dash is totally different from my 95... your best bet would be to ask gearhead43, I know he has done the install and has been a great help with my electrical woes.
Quite different. Besides, you can't cut the '94-'96 dashpads to accomodate the HUD. The entire thing needs to be replaced. Gearhead or Malibuolds are the few I know of
I assume you've looked for a hud dash pad with no luck, but that IMO is the best way to go.
Guest TurboSedan
i got a really crappy dash pad from the same car my HUD came from and used that for quite awhile. i just cut my original non HUD dashpad a few weeks ago. it definately looks alot better than the old warped HUD dash pad. it's not perfect, but looks pretty good. cutting the dash pad was a major PITA! cut...test fit...cut...test fit...over and over. i used a razor to cut the padding away, then i used a Dremel and cutting discs for the hard plastic underneath. i also used a tungsten carbide cutter (a little over kill lol) when i needed to 'carve' the plastic after most of the plastic was already cut away.
http://www.w-body.com/forum/viewtopic.php?t=14960&highlight=cutting+hud
good luck.
