cs-x Posted May 27, 2004 Report Share Posted May 27, 2004 Hello, Can anyone point me in the direction of where the plugs are for installing the DIS? If I have them.. if not, a wiring diagram would help. I have just a plain 89 cutlass if that helps. I'd also like to install the electronic climate control, but I heard that's a bit harder. Also, how hard is it to upgrade to the full cluster? I have 2 of them now, but am a little apprehensive about the rewiring Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted May 28, 2004 Report Share Posted May 28, 2004 before you splice anything for the DIS, look deep and good behind your climate controls, your car might be prewired and they might be tucked up back there. if not follow this: The BLUE connector is C1. Wire A = a RED wire. Connect it to an ORANGE wire that is HOT ALL OF THE TIME. (I connected mine to the ORANGE wire that gives power to the cigarette lighter, but it is recommended that you connect it to the ELEC. Fuse #2 constant +12V (top row, middle fuse).) Wire B = PINK/BLACK. Connect it to a wire that is HOT IN RUN. (I connected mine to one of the PINK/BLACK wire in my dash, but it is recommended that you connect it to CLUST. Fuse #9 switched +12V (3rd row, far right).) Wire C = BROWN. Connect it to the light on input. In my car I have a YELLOW wire in slot C10 but I think that that is exclusive to the digi-dash. I want to soy that there should be a YELLOW wire coming out of the headlight switch that should work. I know that on my dash, when the lights are on, and the display is at MAX, then it has no power in the wire, but when I adjust the lever down, the wire becomes hot, and dims steadily. I use a tester that is just a screwdriver looking thing that has a point at one end, and an alligator clip that you hook up to ground. Wire D = GREY. Connect this to one of the grey wire for illumination. I hooked mine up to the GREY wire that lights up the bulb for the cigarette lighter light. Wire E = BLACK/WHITE. This is a ground. Wire F = BLACK/GREY. This wire is not used. Wire G = YELLOW. Connect this wire to the LITE BLUE wire in the dash (You may not have this wire). This is your English/metric wire. In my car, I push a button on the dash to change it from English (MPH) to metric (KPH). When this wire is hooked up, it automatically changes the DIC display from one to the other when the E/M button is pushed on the dash. This is a wire that is not necessary for the DIC to function, so if you do not have the wire, then just leave it unconnected. Wire H = BLACK. This is a ground. I hooked this up to the BLACK wire connected to the cigarette lighter light. The BLACK connector is C2. Wire A is ORANGE. Connect this to the ORANGE wire coming out of the ALDL connector under your dash. This is your SERIAL DATA INPUT where the DIC will get the info for your gauges button. Wire B = DARK GREEN. Connect this to the DARK GREEN wire in the dash. This is your Vehicle Speed Input. In my car it is wire number D15. Wire C = PINK. Connect this one to the PURPLE wire in the dash. This is your vehicle Fuel sender wire. In my car it is wire number D13. Wire D = BLACK/GREEN. This is another GROUND. It is not used in the 91 model. Driver Info System was not available 92+. You will not find a new cutlass with one. If you put one in your car, then it will go where the storage cubbyhole is under the ashtray. The screw-holes for the 98 Regency’s DIC is identical the Cutlasses, so it will go there with no problem. If you get the DIC out of a Cutlass, then be sure to get the storage pocket as well. IF (OR WHEN) you get the HUD, then the control switch will go where the storage is. 89-90 cars got a little pocket in the empty space. HUD control panel was mounted above the headlight switch (below the dash pad). 91 cars got a little pocket if they didn't have HUD. Cars with HUD got the control panel instead of the pocket. note though that, at least in my car, the short lengths of wire left in my pigtail matched the colors in the car instead of what's listed above. ex: Wire C = BROWN. Connect it to the light on input. In my car I have a YELLOW My wire C was yellow on the pigtail, so it matched the car. another year may have had brown there instead, for whatever reason. also, get all the grounds listed and splice them together first so you can do them all at one time. all of my wires for power/ground go to my cig lighter wires, one to the ALDL connector and like 3-4 into the cluster harness/headlight switch harness Quote Link to comment Share on other sites More sharing options...
