Cornerdealy Posted May 27, 2004 Report Posted May 27, 2004 I'm having some trouble. I need to run a few wires from the engine compartment into the cabin of the car. It's for my fan switches. Now cutty told me that there is a rubber grommet located under the master cylinder that i would need to cut through and i would have access, but i can't find it. BTW, it is for a 1996 3100 sfi. What is the easiest way to get through? Quote
mfewtrail Posted May 27, 2004 Report Posted May 27, 2004 There should be a rubber grommet approximately 2'' in diameter to the right(drivers side) of the brake master cylinder, you can't really miss it. Quote
DiscoStudd Posted May 27, 2004 Report Posted May 27, 2004 It's where the clutch master cylinder mounts on MT cars. Here's a pic of my car I used it to run my amp wiring thru the firewall... Quote
Cornerdealy Posted May 28, 2004 Author Report Posted May 28, 2004 yup i found it, although it wasn't very accessable. Hooked up my switches and now i got a pimp manual fan setup. Now all i gotta do is mount the switches somewhere and i'll be set. thanks guys. Quote
