CutlassQuad.4 Posted May 27, 2004 Report Posted May 27, 2004 Does anyone know how!? :? I need to start my quest to making my car lighter. The thing it a freaking tank, I also might gut the back .. would anyone be interested in the seats? Quote
CutlassQuad.4 Posted May 27, 2004 Author Report Posted May 27, 2004 Ya I need the heater and defrost functions..I live in canada and without it ill FREEZE to death...no joke :shock: Quote
THe_DeTAiL3R Posted May 27, 2004 Report Posted May 27, 2004 I started to remove some of the A/C stuff from my car last summer but put it back together cause its all aluminum and doesn't weigh much at all! The only thing I could see weighting something would be the compressor.. plus that runs off the accessories so it might be a good idea to take it off anyways. Basically just start from the pipes and go from there. I might take mine out just so I got some more room under the hood. Quote
Manny Posted May 27, 2004 Report Posted May 27, 2004 my 2 cents... if you want your defrost to work properly, you may not want to remove your A/C - if your A/C is currently working, when you press defrost, the A/C compressor engages. The defrost uses the A/C system to remove moisture from the car and clear the windows. Ever notice how cars with malfunctioning A/C take forever to clear the windows of fog on a rainy day? If you remove the A/C, of course the defrost will still blow, but won't be as effective. Quote
slick Posted May 27, 2004 Report Posted May 27, 2004 Since you have a quad 4, here you go: http://www.gmpartsdirect.com/ $27.49, GM PART # 22533199 Quote
