whiteSE Posted May 26, 2004 Report Posted May 26, 2004 So how do those covers on the dash come off so you can get to the speaker?? Now I am asking based on a 1988-1993 Grand Prix Dashboard. I don't see any screws - do they just pry off?? I don't want to break them. Thanks guys. Phil. Quote
93CutlassSupreme Posted May 26, 2004 Report Posted May 26, 2004 you might have to remove the dash pad. you have to on a '93 supreme Quote
whiteSE Posted May 26, 2004 Author Report Posted May 26, 2004 Remove the dash pad :x Oh that's not good - Damn you GM!!! Ok, I vented I really need to replace those buzzy front speakers. Thanks. Phil Quote
93CutlassSupreme Posted May 26, 2004 Report Posted May 26, 2004 it's not that hard to remove the dash pad actually. i've worked on other cars where the dash pad is much harder to remove. it's easier if you have someone helping you move it around Quote
mfewtrail Posted May 26, 2004 Report Posted May 26, 2004 To remove the dash pad, there should be two screws above the gauge cluster, then when you open the glove compartment, there will be a ~7mm screw in the center of the glove compartment and straight up(might need a flashlight to see it up in there).. Then you should be able to gently lift up on it until it comes loose and then pull it towards you to completely free it..set it aside and the speaker removal from there is pretty straight-forward. I'm if forgetting anything, I'm sure someone will be along here shortly to correct me. Quote
THe_DeTAiL3R Posted May 26, 2004 Report Posted May 26, 2004 Yep thats about it. Personally I found it less of a pain in the ass to just take the glove box out to reach the one screw... thats up to you. Quote
supreme_style21 Posted May 26, 2004 Report Posted May 26, 2004 :? Mine just popped off with a lil force. Someone must have not replaced the screws. It stayed in place just fine w/o them I guess. Quote
whiteSE Posted May 26, 2004 Author Report Posted May 26, 2004 Well, I guess that doesn't sound too bad.....a job I will have to tackle they sound worse every day and I can't turn a CD up without the speakers cracking. oh well, as soon as it stops raining here I will get right to it. Thanks for all the suggestions - this board is very helpful for technical info. Phil. Quote
digitaloutsider Posted May 26, 2004 Report Posted May 26, 2004 Mine buzz and buzz and buzz and buzz when the engine is on.. It's getting pretty damn irritating. Quote
Bake82 Posted May 26, 2004 Report Posted May 26, 2004 Well, I guess that doesn't sound too bad.....a job I will have to tackle they sound worse every day and I can't turn a CD up without the speakers cracking. oh well, as soon as it stops raining here I will get right to it. Thanks for all the suggestions - this board is very helpful for technical info. Phil. If you need help I'm in Ottawa I could give you a hand if I have time whenever you're planning on doing it. Quote
whiteSE Posted May 26, 2004 Author Report Posted May 26, 2004 If you need help I'm in Ottawa I could give you a hand if I have time whenever you're planning on doing it. Thanks man I appreciate that - I may come looking for you if I get in trouble Quote
