musthavemuzk Posted May 25, 2004 Report Posted May 25, 2004 saw a tip about oiling them prior to installing them. nice tip but my question is do the injector o-rings need to be changed each time you remove injectors? i changed the lower intake on my cutlass last fall late and put new injector o-rings in at that time. soon it is to go back together after head work. will i need to put new injector o-rings in? Monty Quote
Robby1870 Posted May 25, 2004 Report Posted May 25, 2004 saw a tip about oiling them prior to installing them.nice tip but my question is do the injector o-rings need to be changed each time you remove injectors? i changed the lower intake on my cutlass last fall late and put new injector o-rings in at that time. soon it is to go back together after head work. will i need to put new injector o-rings in? Monty Yes, I recommend changing them. But, if you do it right, you will only have to change the o-rings where they meet the manifold. You can pull the rail with injectors in, out at the same time. Its just a precaution thing. Usually they wont tear when you pull them out, but sometimes they do tear Quote
musthavemuzk Posted May 25, 2004 Author Report Posted May 25, 2004 well i did not like the price i paid for them, but it is much cheaper than replacing the engine from a fuel leak turned blaze. guess i will just put them on my list of parts to buy. thanx Robby Monty Quote
Canada Posted May 25, 2004 Report Posted May 25, 2004 Its only like $6 for the entire set of O-rings.... Quote
Robby1870 Posted May 25, 2004 Report Posted May 25, 2004 Its only like $6 for the entire set of O-rings.... When I buy them, they come in a box of 12 and its about $12 bucks for them....a bit pricey, but that covers two times of taking them out. Quote
WhiteOut Posted May 25, 2004 Report Posted May 25, 2004 I just reused my old ones because when I went to Napa they were like $5-6 for a set, and the guy said I needed six sets (for six injectors). I said screw that and I just sprayed the old ones down with silicone spray. Quote
Robby1870 Posted May 25, 2004 Report Posted May 25, 2004 You can buy just the bottom o-rings for the injectors, just have to know what to ask for. Quote
4spdz34 Posted May 25, 2004 Report Posted May 25, 2004 u shouldn't have to replace them. and if u did replace them once i wouldn't do it again, just make sure they aren't tore and grease them up they will be fine Quote
gp90se Posted May 25, 2004 Report Posted May 25, 2004 Right click and click show pic, otherwise http://community.webshots.com/s/image6/8/84/49/92888449lXamCK_ph.jpg Need I say more? -Jeff Quote
musthavemuzk Posted May 25, 2004 Author Report Posted May 25, 2004 i knew i had seen something about a fire after a fuel leak but i could not recall who and so on. Monty Quote
Heza Posted May 25, 2004 Report Posted May 25, 2004 You can buy just the bottom o-rings for the injectors, just have to know what to ask for. no you cant. i was just at the dealership to buy them. set of 18 (2 lower/1 upper per injector) is in the kit. you CANNOT just buy the lower rings. ...and its $15. Quote
god910 Posted May 25, 2004 Report Posted May 25, 2004 Shit, I'd be one broke bitch if I replaced them every time I removed them. I'd have to buy stock in that fukin company. I bought a kit from adv. auto and all the O-rings were the same. No diff. between upper and lower (that I could tell anyhow. ) Quote
