Weird ratteling and puffing sound
Ok just this morning as i was moving my car i noticed the RPMS kicking up a lil to 1000 and falling back to 800 or so. It was doing this every 10 seconds then i get out to the rear of my car and by the exauhst pipe i put my hand by the tip of it and it was maming a put put sound every 10 seconds as it did inside my car. Anyone have any idea wats going on can it be the catalyst converter is getting cloged ?
sleep? what's sleep? :lol:
sounds like a misfire
bad gas, spark plugs are shot, spark plug wires are shot...stuff like that
You can tell much by putting your hand up to the tail.
If it is regular, and you can feel a puff at the pipe, and you can see your tach, I would bet it has to be fuel delivery.
Maybe some restriction (such as a filter) or a pump that cannot keep up for some reason or another.
Take the chaep and obvious first in the filter, and then check your pump connections. If still doing it take a close look at replacing the pump.
If you still think your catalytic converter might be to blame, hit it w/ a rubber hammer/mallet(not hard, but hard enough to shake it basically), if you hear stuff(catalyst material) rattling inside it, the cat needs to be replaced because the broken catalyst can cause a restriction in the exhaust system.
