I have a problem with my lighting in my '96 Cutlass. All buttons, gauges, misc lights in the car dim really low when ever the headlights are turned on. Now this happens all the time but sometimes they work correctly. The problem would seem to be coming from the dimmer switch, but its not. The switch works great when the lights work. Also the dimmer switch has been replaced and problem has not corrected itself.
Any ideas?
Mine used to do that, it would slightly dim with the head lights on and turn signal on. If you still have the orignal batery it might be to the point were its not supply enough juice to power every thing at once.
