Ecm interchange??
I know all of the early w-bodies I have poked at have the 727 ecm. Is this the same ecm the vette used?? I would like to do the speed density swap on my TPI but want to make sure that it is indeed the right ECM before I rip one out and repin my harness.
You should be able to use it as long as you have the right PROM chip in the ECM.
Proms are not a problem. I have a friend who can burn whatever I need. Once I get things swapped over I will probably start burning my own though.
I would be doing for an F-body so he would use tuner cat and a bin file for the 730.
