boostnawd Posted May 24, 2004 Report Posted May 24, 2004 How tough is this on a 92 DOHC? Is it just a matter of pulling out the coolant reservoir, taking the serpentine belt off and undoing the bolts? Or am I looking at more work. Quote
White93z34 Posted May 24, 2004 Report Posted May 24, 2004 when i changed it on a 3.1 it was a walk in the park, and since the 3.1 and 3.4 are quite similar i would imagine its just as you described. Quote
boostnawd Posted May 24, 2004 Author Report Posted May 24, 2004 I'm hoping it's that easy and not like the alternator procedure. Anyone else? Any special procedure for installing the new one? Teflon tape anywhere? Any hints/ suggestions welcome. Quote
brian89gp Posted May 24, 2004 Report Posted May 24, 2004 Loosen the 4 pulley bolts with the belt still on, remove the belt, remove the 4 bolts and pulley, then the 5 bolts on the pump itself. Scrape the old gasket and use a new one. If you don't want coolant everywhere then drain it. Quote
