3100 oil pump drive seal HELL! (pictures) *NEW DISCOVERY!*
ok, as most of you mightve known, i posted i was gonna do the repair on my old '94 SE. let me first note, that the 3100 is different from the 2.8/3.1 to repair. on the 2.8/3.1, you dont need to take off the upper intake manifold. on the 3100, you HAVE to.
anyway...i got down to it and figured out that my o-ring probably isnt leaking, but my right lower intake gasket might be. it has a huge glob of goo hanging from it and is positioned higher than the o-ring. or is this just part of the oil pump drive seal mess? i dont see how it could be.
i wish i could post bigger pictures, but all i got is cardomain. inputs would be more than welcome. im getting more parts to pull the lower intake off too and change all gaskets while im at it.
the damn oil pump drive location
...and if you can tell...the damn gooey looking lower intake gasket
EDIT - i just looked at the RTV sealant again this morning and noticed a puddle of antifreeze sitting on top of it. suggestions? ...PLEASE?!?!
...also...to take the fuel rails off...do i just depressurize them, undo the two bolts and pull them off? or do i need to do something else?
thanks anyone.
That goo is RTV silicone. Thats what you use to seal the lower intake against the valley on the block. Its normal for that to stick out like that, in fact it should stick out like that to properly seal.
Guest Anonymous
If you pull the fuel rail make sure you rock it back and forth while pulling up. And before putting it back in get new o-rings and put a thin layer of oil on the o-rings. The oil helps get the back in without tearing them. :D
once the bolts are off of the fuel rail pry against the bottom of the injectors lightly with a screwdriver or pry bar
ok...if that's the case....could it still just be the oil pump drive seal? the oil *EDIT - antifreeze* is living it up on that RTV sealant blob. if i dont have to take the lower intake off, id love not to.
Guest Anonymous
If you found anti freeze I would pull the lower intake and do new gaskets from there up.
Prolly the lower intake gasket, but check the coolant fitting on the lower intake......its been known to leak
thanks for the inputs. i planned on going from the lower intake up. i got the lower intake gaskets and uppers. just have to go buy valve cover gaskets and new injector o-rings....well....a few other random things too.
most definitely change that crappy fitting on the lower intake while it is in plain site.
that is what started all my learning last fall.
not a bad thing...just one of them learning things
that is a good tip on oiling the injector o-rings.
wish i had known that when i put mine back together.
will know for next time though.
Monty
fucking GM...got this from alldatadiy.com. still had a subscription that i forgot about.
Engine - Increased Oil Consumption
File In Section: 6 - Engine
Bulletin No.: 87-60-03
Date: September, 1998
Subject:
(Replace Lower Intake Gasket)
Models:
1994-96 Buick Century, Regal, Skylark
1994-96 Chevrolet Lumina, Monte Carlo
1994-96 Oldsmobile Achieva, Cutlass Ciera, Cutlass Supreme
1994-96 Pontiac Grand Am, Grand Prix
with 3100 V6 Engine (VIN M - RPO L82)
Condition
Some owners may comment on a sudden increase in engine oil usage as the vehicle mileage approaches 30,000 miles. The increase in engine oil usage is dramatic, typically in the 600-800 miles per 1 quart range (965-1287 kilometers per 0.946 liters). Normal oil economy ranges in the less than 1 quart in 2000 miles (0.946 liters in 3218 kilometers).
Cause
After prolonged exposure to fuel enriched air and thermal cycling of the engine, the lower intake manifold gaskets take a compression set. Engine oil is then drawn into the lower intake manifold and ingested along with the air fuel mixture. Due to the internal thermal temperatures and the efficiency of the catalytic converter, no engine oil smoke is visible from the vehicles exhaust tailpipe.
Correction
Reference Corporate Service Bulletin 766004 and follow the guidelines set forth in it. Check for any external oil leaks and then complete an oil consumption test. If it is determined that the vehicle is using oil at a rate greater than 1 quart (0.946L) in 2000 miles (3218 km), replace the lower intake manifold gaskets.
also...when i was at the GM parts department, the guy even told me that DEXCOOL will eat gaskets apart. ...yet, GM wont admit it.
are the 3100 lower intake gaskets harder to do then the 3.1 MPFI?
havent worked on a 3.1 MPFI, but im very certain it is easier.
Subject:
Models:
Condition
Cause
Correction
HOORAY!!! -- I think you just solved my problem! My car has been drinking oil at the rate of about 1-1/2 - 2 Qts per 3000 miles for quite a while. Now ill go do a compression test on my engine and if all is good then i know all i need to do is replace some gaskets. I was thinking that my valve guides and/or rings were worn.
grandprix104....ill let you know if its all true. i finally finished the project last night, but got a coolant leak from the heater inlet pipe. fixed it tonight and the motor is seemingly doing well. flushing the radiator, changing the oil and tranny fluid tomorrow and then going to see how the oil consumption changes.
....i hope, and hope some more, back to normal!
