89Cutlass Posted December 5, 2002 Report Posted December 5, 2002 I have an 89 Cutlass supreme and it idles way to high most of the time and you can here crackling around the catylitic converter. Im wondering if this is the problem. anyone have any ideas. Quote
Guest Anonymous Posted December 5, 2002 Report Posted December 5, 2002 Hit the catalytic conv. with a hammer and see if anything rattles around inside. Don't hit it too hard and put a hole in it though. Quote
90lumina3.1 Posted December 6, 2002 Report Posted December 6, 2002 i tried hittin mine with 4 kinds of hammers! i knew it was broken, just wanted to see if it was rattling. used steel, lead, rubber, and some other kinda hammer. never put a hole in it, original cat with 119k on it Quote
89Cutlass Posted December 6, 2002 Author Report Posted December 6, 2002 I HIT IT AND THERES LOTS OF RATTLING GOING ON IN THERE.. Quote
89Cutlass Posted December 6, 2002 Author Report Posted December 6, 2002 Could this be the reason for high idling sometimes being it being partially clogged. and sometimes no response from gas pedel. ive tested all the sensors are fine new plugs,wires,battery,fuel pump all new.. Quote
GnatGoSplat Posted December 6, 2002 Report Posted December 6, 2002 I'm not aware of high idle being a symptom of a clogged cat. Rattling near or around the cat could just be the heat shield. Do you have any other driveability symptoms? Quote
89Cutlass Posted December 6, 2002 Author Report Posted December 6, 2002 no the car drives great except for the high idle and its only sometimes that it does it too.. its not the heat sheild. Ive checked that the inside of the cat is all broken up when i bang on it you can here pieces rattlling around.. Craig Quote
GnatGoSplat Posted December 6, 2002 Report Posted December 6, 2002 High idle is usually due to a vacuum leak or intake manifold leak. Spray around your engine with carb cleaner and see if you can detect any change in engine RPM. Quote
GnatGoSplat Posted December 6, 2002 Report Posted December 6, 2002 Spray around the intake manifold gaskets, plenum gaskets, vacuum lines, etc. Quote
