Guest donkeykongrape Posted February 5, 2006 Report Posted February 5, 2006 I did the seal today on my 3.1....I got some pics here at http://steve.neoturbine.net/pics/cut_supreme/oil_pump_drive_seal/ if that helps anyone at all And BTW...i took the oil pump drive out with no force at all, i lifted a tiny bit w/ a screwdriver and it just slid out....interesting Quote
Prospeeder Posted February 5, 2006 Report Posted February 5, 2006 does the oil pump drive have to go in a certain way for the teeth to line up on the camshaft or it just goes in fine and easy? Quote
5speedz34 Posted February 5, 2006 Report Posted February 5, 2006 does the oil pump drive have to go in a certain way for the teeth to line up on the camshaft or it just goes in fine and easy? Well you need to play with it to get the gears to mesh. FWIW: Every motor is different difficulty wise. It took me a good hour of swearing to get mine out of the Cutlass, and it pulled out the rod with it too. Quote
Bossman429 Posted February 5, 2006 Report Posted February 5, 2006 Yeah, the shaft on my Beretta pulled out easily by hand. The shaft on the TSTE was in there pretty good. I just gripped it with a big pair of channel locks, and wiggled around to pop it out. Every time I do these I also buy a distributor shaft seal for a SBC, and install it under the drive shaft before re-assembly, if the o-ring ever starts to seep or leak, the gasket will keep the oil from leaking all the way out. The shaft to drive the oil pump is a hex shape, so you do have the have the drive gear in the right position to get it to engage all the way. It's not that hard, just drop it in there a few times until it falls all the way in. Quote
Highlander Posted October 31, 2007 Report Posted October 31, 2007 You can also do the TB Coolant Bypass Mod while repairing the O-ring seal. Maybe Shaun can get the right hose P/N for the TB Bypass.. I had them at one point but misplaced it. OK, I resurrecting the dead with this old topic, and maybe this is a dumb question, but what's the benefit of bypassing the TB? Or maybe, what's the drawback? Thanks. Quote
Addicted To Boost Posted October 31, 2007 Report Posted October 31, 2007 Benefit (possibly) cooler intake temps. Drawback- If you're in a cold climate, there is a possibility of your throttle getting stuck in really cold temps. Quote
Fleeingpepper Posted March 2, 2008 Report Posted March 2, 2008 What are the chances of getting the pictures back up sometime soon? Hmm? Quote
sonick Posted April 10, 2008 Report Posted April 10, 2008 Where/how do I release the fuel pressure? Quote
ManicMechanic Posted April 10, 2008 Report Posted April 10, 2008 I just pop the fuel cap, then pull the ecm or fuel pump fuse and crank it over for a minute. Quote
19Cutlass94 Posted April 11, 2008 Report Posted April 11, 2008 Where/how do I release the fuel pressure? on the fuel rail. Quote
hmdznrcld Posted April 14, 2008 Report Posted April 14, 2008 I just tore down the 92 GP I just bought, once everything was out I was able to just pull the darn plug up with my fingers! I KNOW this thing was leaking oil. I did change the gaskets and the plug o-rings, the front side plug holes had quite a bit oil. Is there a gm part no. for the o-ring? (NEVER MIND I LOCATED IT) hmdznrcld aka RUNDLC Quote
sloick Posted June 25, 2009 Report Posted June 25, 2009 im going to bring this back alive for the simple reason that this can be done with alot less effort. heres what i did on mine: tools rqd. 1. #45 O-ring from hardware store (or the GM one if you want) 2. 13mm socket with a crap load of extensions 3. 13mm open end wrench 4. T-10 torx *(if needed for the sensor on throttle body) 5. a good degreaser or brake parts cleaner 6. a good magnet 7. oil resistant rtv sealant pull the air box and intake tube out, unbolt the crossover pipe. their are 3 bolts in each connection, 1 on each you really cant see. the back connection requires about 2 feet worth of extensions on the socket. they are all 13mm. i could not physically remove the crossover pipe because the master cyclinder is so tight, so i moved it out of the way as much as possible. after the cross over is moved, use a 13mm wrench to remove the retainer bolt. clean the crap out of the area with a good degreaser, or brake parts cleaner. slide the oring over the shaft. its tricky but can be done. then pry up on the shaft and shim it up while you do the next part. (i used a small craftsman screwdriver.) then slide the o ring over the wide part of the shaft, getting it under where it belongs. *i needed two hands so i had to remove the top sensor on the throttle body to get my are down there (93 motor.) once its in i used a crap load of rtv and smeared it in there as best i could, turning the shaft to ensure it was all over. then reassemble. make sure you plug all sensors back in, IAT, MAF doing it this way alot less had to come off making it alot quicker of a job. it took me about 2 1/2 hours from the time i pulled the car in to the time all the tools were cleaned up (and picking up after my 4 year old son.) i hope this helps someone save some time. http://60degreev6.com/forum/attachment.php?attachmentid=719&d=1174459029 http://60degreev6.com/forum/attachment.php?attachmentid=720&d=1174459029 http://60degreev6.com/forum/attachment.php?attachmentid=721&d=1174459029 http://60degreev6.com/forum/attachment.php?attachmentid=722&d=1174459099 http://60degreev6.com/forum/attachment.php?attachmentid=723&d=1174459099 http://60degreev6.com/forum/attachment.php?attachmentid=724&d=1174459099 http://60degreev6.com/forum/attachment.php?attachmentid=725&d=1174459174 http://60degreev6.com/forum/attachment.php?attachmentid=726&d=1174459174 ~i stole this method and pictures from another website.~ Quote
White93z34 Posted June 25, 2009 Report Posted June 25, 2009 that is an innovative way of going about it. I did something similar with a O ring a few years back, however I took the hard way and tore the intakes down to get there. Quote
Crazy K Posted September 5, 2009 Report Posted September 5, 2009 (edited) ***the info following is applicable to all engines with remote oil drive in terms of the parts, location and recommendations... the difference is on other motors you can extract the unit without pulling a head, I provided the following to make it possible to do the job on the most difficult variant of oil drive configurations*** 3.4 specific instructions: There is a specific O-ring for this job. Go to your dealer and get the BROWN silicone O-ring.(oil/distributor drive O-Ring, brown silicone rubber - 10477565) they will know what you need. ask for a "OIL DRIVE O-RING" there or any reputable parts shop. next.. GET A PAPER GASKET. One for a 1980 anything chevy v6 will work, but you can make your own. WHY? You should DOUBLE GASKET this seal. I do on all the 60V6s I've ever touched. You cannot reach the O-ring on the drive gear due to clearance on this motor (91-95 for sure) You must make the clearance. CLEARANCING HEAD: I do not like hacking the head completely, which would remove the bolt hole for the lower intake, so instead I removing maybe 1/4 inch of material with a hacksaw blade from the area right above the seal. This leaves the bolt from the lower intake functional, but thins the tab of metal hanging below it without harm. You will need to remove a little of the very lowest portion of the bolt's hole. CLEARANCING OIL GEAR:Next, I recess the "freeze-plug" type cover in the center of the drive-gear by tapping it down from above with a couple linked 3/8" extensions, turning it (or moving the extension) so the plug moves uniformly. Using the hacksaw blade again, I notch into the top of the drive-gear level with the top of the recessed cap. Cut about 1/4 of the radius, and a quick tap with a screwdriver will pop the cut section off. hack the edges clean, and even sand to de-bur so you don't damage the new o-ring. The gear should lift high enough to have the bottom of the O-ring at or above the level of the block. Cut or break the old ring out. Grease or oil the new ring and the drive-gear cap (I prefer dielectric grease) and slip it over the cap, stretching it over and sliding it down until in position. (note that I used some scrap insulated electrical wie to drag it) Degrease the area and get the paper gasket. Cut the paper gasket and rub it with a RTV sealant. wrap it around the oil drive, make sure it is straight and slam that oil-drive gear home and bolt it down. image album of what I did: http://s28.photobucket.com/albums/c214/Crazy_Ken/LQ1%20oil%20drive%20fix/ Edited February 15, 2013 by Crazy K Quote
dtom4 Posted March 30, 2010 Report Posted March 30, 2010 3.4 specific instructions: There is a specific O-ring for this job. Go to your dealer and get the BROWN silicone O-ring.(oil/distributor drive O-Ring, brown silicone rubber - 10477565) they will know what you need. ask for a "OIL DRIVE O-RING" there or any reputable parts shop. next.. GET A PAPER GASKET. One for a 1980 anything chevy v6 will work, but you can make your own. WHY? You should DOUBLE GASKET this seal. I do on all the 60V6s I've ever touched. You cannot reach the O-ring on the drive gear due to clearance on this motor (91-95 for sure) You must make the clearance. CLEARANCING HEAD: I do not like hacking the head completely, so instead I removing maybe 1/4 inch of material with a hacksaw blade from the area right above the seal. This leaves the bolt from the lower intake functional, but thins the tab of metal hanging below it. You will need to remove a little of the very lowest portion of the bolt's hole. CLEARANCING OIL GEAR:Next, I recess the "freeze-plug" type cover in the center of the drive-gear by tapping it down from above with a couple linked 3/8" extensions, turning it (or moving the extension) so the plug moves uniformly. Using the hacksaw blade again, I notch into the top of the drive-gear level with the top of the recessed cap. Cut about 1/4 of the radius, and a quick tap with a screwdriver will pop the cut section off. hack the edges clean, and even sand to de-bur so you don't damage the new o-ring. The gear should lift high enough to have the bottom of the O-ring at or above the level of the block. Cut or break the old ring out. Grease or oil the new ring and the drive-gear cap (I prefer dielectric grease) and slip it over the cap, stretching it over and sliding it down until in position. (note that I used some plastic coated wiring to drag it) Degrease the area and get the paper gasket. Cut the paper gasket and rub it with a RTV sealant. wrap it around the oil drive, make sure it is straight and slam that oil-drive gear home and bolt it down. image album of what I did: http://s28.photobucket.com/albums/c2...20drive%20fix/ This is interesting. I tried to do the oring a few years ago and couldn't get the shaft out because it was hitting the head. Ground the lip holding the freeze plug cap down to get some clearance but couldn't grind enough to clear and the cap popped off. Ended up jb welding the cap back on and rtv'ing the shaft instead of replacing the oring. Its held up ok so far but I never felt comfortable with the "repair". Not sure how all you guys are getting the shaft out without grinding something. Been tempted to redo it but too much work. Would like to see your pics but link isn't working. Can you repost? Thanks Dave 93 Lumina Z34 Quote
Crazy K Posted May 6, 2010 Report Posted May 6, 2010 This is interesting. I tried to do the oring a few years ago and couldn't get the shaft out because it was hitting the head. Ground the lip holding the freeze plug cap down to get some clearance but couldn't grind enough to clear and the cap popped off. Ended up jb welding the cap back on and rtv'ing the shaft instead of replacing the oring. Its held up ok so far but I never felt comfortable with the "repair". Not sure how all you guys are getting the shaft out without grinding something. Been tempted to redo it but too much work. Would like to see your pics but link isn't working. Can you repost? Thanks Dave 93 Lumina Z34 thanks. Fixed! Quote
99screaminregal Posted May 7, 2010 Report Posted May 7, 2010 Did mine last monday and followed Ken's instructions. Also had to pull the crossover. Easy way to do it, pull the driver side fan and bend the air box mount tab down to easily pull the pipe out. Cracked about a 1/4 of the tab off the top of the gear. Took a few minutes to slide the o-ring on. BOIL IT IN WATER!! Loosens it perfectly. OH YEAH! Crossover nuts..... Torque is 18 ft./ lbs. Thank you 60degreev6.com. Quote
Leadfoot Posted July 18, 2010 Report Posted July 18, 2010 Going to be doing this in the near future. It has been a long time since I have messed with the throttle body. Do I need a throttle body gasket for this? Quote
RobertISaar Posted July 18, 2010 Report Posted July 18, 2010 perferably. you really don't want vacuum leaks. not sure how will silicone would work here. Quote
Crazy K Posted July 18, 2010 Report Posted July 18, 2010 I experienced the pop cap phenomenon, myself. I bent the edge out a bit and shoved it back in place and then coated the top with RTV. NOTE TO ALL... try to cut above the level of the cap insert. it protects lubricant on a bearing on the top of the drive gear, though it is not under pressure from the oil sytem. Quote
eeltam Posted December 22, 2010 Report Posted December 22, 2010 Will these methods work for a 94 3.1? I went to look at mine and it was hard to tell. Quote
Crazy K Posted July 29, 2011 Report Posted July 29, 2011 Will these methods work for a 94 3.1? I went to look at mine and it was hard to tell. the parts you need are the same(gasket, paper backup gasket), but I would pull the plenum and intake instead of the exhaust for access. Only the LQ1 requires the hack, all other engines don't. Quote
Psych0matt Posted September 21, 2011 Report Posted September 21, 2011 I didn't have to relieve fuel pressure, I just lifted the fuel rail our of the way, held temporarily out of the way with a zip tie Quote
GOT2B GM Posted September 21, 2011 Report Posted September 21, 2011 I've gotta do this on my black vert, just bought the brown GM silicone o-ring and the dizzy gasket. Quote
