90TGP Posted December 4, 2002 Report Posted December 4, 2002 I just got my front lowering springs for my TGP. I got the 94+ Lumina/ Monte Carlo front springs from http://www.JCWhitney.com. I have to wait till I get my new struts and rear swaybar put in before I can get these installed though. Quote
manualturbo Posted December 5, 2002 Report Posted December 5, 2002 do u have the rear lowered? and if so how? or if not do u know how? thanks, mitch 90 tgp 5 speed Quote
1trucavalier Posted December 6, 2002 Report Posted December 6, 2002 rsm gives you instructions on how to lower the rear by and inch but of course you have to buy there lowering springs first Quote
dykz34 Posted December 9, 2002 Report Posted December 9, 2002 Fuck RSM. Get the coilovers. Oh ya, whats the point in posting saying that you received the springs? Honestly, not to be a dick but, no one cares. Quote
Chris A Posted December 9, 2002 Report Posted December 9, 2002 I do! It good to hear about POSITIVE things happening. Maybe he'll let us know how the install goes too! Quote
dykz34 Posted December 10, 2002 Report Posted December 10, 2002 Install? http://www.dykz34.com/lowering.htm Quote
Guest TurboSedan Posted December 10, 2002 Report Posted December 10, 2002 Install? http://www.dykz34.com/lowering.htm i noticed you didn't use a 2-jaw puller (for tie-rod end & push axle out of hub) or a pickle fork (for lower ball joint) ....you didn't actually get the balljoint and tie rod out with a flathead screwdriver did you? joshua Quote
1trucavalier Posted December 11, 2002 Report Posted December 11, 2002 dykz34! nice website! what did you do to your vac mod? Quote
dykz34 Posted December 11, 2002 Report Posted December 11, 2002 LOL, no, I didnt use a screwdriver.... I used a hammer to pound them up. Not that it mattered, I replaced the ball joints and the tie rod ends. Vaccum modulator? I unplugged it, but then plugged it back in cuz it sucks. Quote
dykz34 Posted December 11, 2002 Report Posted December 11, 2002 Also, my axle came right out with just pushing with my hand.... Quote
Steve LS Posted December 12, 2002 Report Posted December 12, 2002 Would you say those front springs are higher rate, same , less? Do they also fit 91 Regal? Where do I locate them? Quote
90TGP Posted December 13, 2002 Author Report Posted December 13, 2002 They should fit the Regal. Look for the 1994+ Lumina/Monte Carlo front lowering springs from http://www.JCWhitney.com The part number is #81ZX0113T Quote
RedZMonte Posted December 16, 2002 Report Posted December 16, 2002 Would you say those front springs are higher rate, same , less? Do they also fit 91 Regal? Where do I locate them? they are definatly a higher spring rate, so your car will definatly hadle better. and JCwhitney is the place to get them. they should fit all 1st gen W-bodies and 1.5gen W-bodies. RedZ Quote
90TGP Posted December 17, 2002 Author Report Posted December 17, 2002 I also just recieved my KYB GR2 struts [all four]. Quote
