whiteSE Posted May 16, 2004 Report Posted May 16, 2004 My front valve cover appears to be leaking some oil so I am going to change the gasket , easy but... there is a pipe either related to the cooling or the A/C that runs accross the valve cover and it is in the way. Does it remove easily or is there a procedure to remove it?? MY tech manual doesn't mention it at all. Thanks for any help. Phil. Quote
Guest TurboSedan Posted May 16, 2004 Report Posted May 16, 2004 yup you need to remove it. it isn't hard to remove, just unbolt it from the top of the water pump, undo the clip for the spark plug wires, and disconnect it from the throttle body. you will need to bleed the air from your cooling system after you are all done. Quote
Slade901 Posted May 16, 2004 Report Posted May 16, 2004 When I replaced the valve cover gasket on mine vehicle 1990 Cutlass 3.1L V6, I just removed the front dog bone and its bracket. Removed the two small bolts on the left side of front dog bone bracket. http://members.fortunecity.com/slade901/automobile/1990Cutlass3.1LV6_ValveCoverGasketReplacement.jpg Quote
whiteSE Posted May 16, 2004 Author Report Posted May 16, 2004 Thanks guys, didn't think it would be a big deal. Why must everything be packed so tightly!!! Phil. Quote
