Dirty Rockstar Posted May 14, 2004 Report Posted May 14, 2004 Drivin along thois afternoon, I am cruisin down MN 120, and I get out of the gas, then the RPMS drop to where they normally do (~750-800) then drop to below the 0, and it dies.. It only happens when in gear, and if I can get into Neutral fast enough, it doesn't stall.. Of course, I stopped at a light, threw it in park, and shut it off, then restarted it.. It didnt do it after that.. Any info, because I have a 40 mile trek to work tonight.. Cant be late, lol.. Thanks guys! Quote
THe_DeTAiL3R Posted May 14, 2004 Report Posted May 14, 2004 Tuneup! First I'd check the fuel system basics- clean the TB and IAC. Put some good fuel injector cleaner in the tank. Check your plugs, wires, etc. Quote
Dirty Rockstar Posted May 14, 2004 Author Report Posted May 14, 2004 Itjust couldnt wait, cou;d it? That happens over memorial weekend.. ANd anyway, it went away for now.. I'll keep my eye on it Quote
excelsior Posted May 17, 2004 Report Posted May 17, 2004 check fuel pump....i had EXACT same problem and my fuel pump went...keep in mind my car has just 80 k miles on it :shock: Quote
cs-x Posted May 28, 2004 Report Posted May 28, 2004 my fuel pressure regulator went once, and I had the same problem.. stalling that happened at the wierdest times.. maybe not the problem, but something to look at. after I had it changed out with one from the junkyard, it worked perfect and has ever since Quote
Dan94Z34 Posted June 6, 2004 Report Posted June 6, 2004 check your fuel pressure with a pressure guage on the shradder valve on the fuel rail. When was the last time you changed your fuel filter? A cloged fuel filter can make a car do that at highway speeds. Quote
