90TGP Posted May 13, 2004 Report Posted May 13, 2004 So, how do I go about replacing my brake rotors and pads on my 90 TGP??? Quote
Big Blue Posted May 13, 2004 Report Posted May 13, 2004 I don't want to sound like a jerk but isit the front are rear we're talking about also do you want step by step for front disc brakes 1 Take of the wheel's 2 losen/take of the master cylinder cap 3 remove the 2 bolts that hold the calipers in place(1 side at a time) 4 get a flat head screw driver and pry off the caliper(be carful) 5 Get a pieace of wire,like a coat hanger and attact it to the strut and then the other end to the caliper(don't let it hang by the brake line) 6 take out the brake pads 7 using a buffing wheel clean up where the brake caliper sits(also the same one the bolt's make sure they are nice and clean 8 TO remove the rotor,is very easy on are cars it's a floating rotor so all you have to do is remove the bracket that holds the caliper in place and it slides right off. 9make sure you lossen the master cylinder cap/taken it off 10 using the old pads and some plyers(will fix my post with the proper name)take one of the old pads and put it in the caliper like you would be putting in new pads,but take those plyers and push back the pistons 11 reinstall the new pads,and do all these steps vice versa also to bleed the system,pump the brakes up as hard as you can(don't put the brake to the floor)then start the vehicle and the brake should drop.(if it doesn't drop then you need a new master cylinder)money money hear you go,the steps for front disc brakes. i will fix it up a little more Kyle Quote
digitaloutsider Posted May 14, 2004 Report Posted May 14, 2004 A front brake job is easy as pie. The rear ones are a bit diffcult because of the placement of bolts and the fucking parking brake assembly. Quote
z34_nut Posted May 14, 2004 Report Posted May 14, 2004 make sure that while you have the back calipers off, put anti-seize in the pistons to make sure they don't seize up later. Quote
mfewtrail Posted May 14, 2004 Report Posted May 14, 2004 I don't want to sound like a jerk but isit the front are rear we're talking about also do you want step by step for front disc brakes 1 Take of the wheel's 2 losen/take of the master cylinder cap 3 remove the 2 bolts that hold the calipers in place(1 side at a time) 4 get a flat head screw driver and pry off the caliper(be carful) 5 Get a pieace of wire,like a coat hanger and attact it to the strut and then the other end to the caliper(don't let it hang by the brake line) 6 take out the brake pads 7 using a buffing wheel clean up where the brake caliper sits(also the same one the bolt's make sure they are nice and clean 8 TO remove the rotor,is very easy on are cars it's a floating rotor so all you have to do is remove the bracket that holds the caliper in place and it slides right off. 9make sure you lossen the master cylinder cap/taken it off 10 using the old pads and some plyers(will fix my post with the proper name)take one of the old pads and put it in the caliper like you would be putting in new pads,but take those plyers and push back the pistons 11 reinstall the new pads,and do all these steps vice versa also to bleed the system,pump the brakes up as hard as you can(don't put the brake to the floor)then start the vehicle and the brake should drop.(if it doesn't drop then you need a new master cylinder)money money hear you go,the steps for front disc brakes. i will fix it up a little more Kyle It's not a "floating rotor"...we having floating brake calipers. BTW, like Davis pointed out, you have to turn the rear caliper pistons to push them back in...the tool that makes this job simple looks like a box w/ slots for your 3/8'' drive ratchet to fit into... found a picture for you. http://www.mytoolstore.com/kd/3163.gif Also, something I don't think anyone here mentioned...apply anti-squeal gel to the clips on the backs of the pads. The anti-squeal stuff is like $.99 per package and you can easily do ALL the pads w/ it. Quote
Lee Posted May 14, 2004 Report Posted May 14, 2004 Got cash? Do the fronts yourself, take it in for the rears. I've had my car over seven years, done the rears twice and each time I swore I'd take it in the next time. I'll probably do it myself again.....and swear I'll take it in the next time Quote
SUPERDUTYD Posted May 14, 2004 Report Posted May 14, 2004 don't you have to remove the parking brake on the rears? i know i did and that made it harder to do. Quote
90TGP Posted May 14, 2004 Author Report Posted May 14, 2004 Eh, sounds complicated. I'm just going to have my dads friend do it for me. He has a ton of specialty tools and has a lift in his garage [yeah, he had one installed in the new house he bought :shock: ]. Quote
Z34door Posted May 14, 2004 Report Posted May 14, 2004 after the last time i did the rear brakes i swear im just going to put new calipers on this time. Quote
