White93z34 Posted May 13, 2004 Report Posted May 13, 2004 ok in my cars 11 years the drivers door no longer hangs perfect, it sags a little but what i'm most concerned about it that it rubs on the fender when i open the door. how do i realign the door so it does not do this any more? Quote
slick Posted May 13, 2004 Report Posted May 13, 2004 From what i hear, its just a few bolts in the door jam. You might have to put some shims in there, but i could be wrong. Quote
phantomshado Posted May 13, 2004 Report Posted May 13, 2004 You'll have to pull the fender off to get to the bolts that control the sag. line up the door with the back fender, adn you're all sorts of set. Quote
Brian P Posted May 14, 2004 Report Posted May 14, 2004 I have new drivers side hinges for sale if you're interested Quote
GnatGoSplat Posted May 14, 2004 Report Posted May 14, 2004 Grab the back of the door and see if you can lift up at all. If you do, you need new hinges. BTW, the doors are damn ass heavy. PITA to get aligned perfectly even with a helper. Quote
