cryptnix Posted May 13, 2004 Report Posted May 13, 2004 I went into a ditch not to long ago and I happened to notice when I was changing my fuel filter that the cable that I'm assuming goes to the E-Brake had its little hangers bent ... could this actually be something serious by causing my rears or w/e or ... good grief ... what could it do i guess Quote
cryptnix Posted May 13, 2004 Author Report Posted May 13, 2004 umm, i'm basically just asking if it'd cause it to basically deploy alittle pressure to it ... Quote
THe_DeTAiL3R Posted May 13, 2004 Report Posted May 13, 2004 Jack up the rear and take the back tire off. Does the wheel turn without resistance? Mine have a little resistance, but my calipers are fucked. The e-brake has a crappy little cable with bolts on it for adjustment, which are about halfway across the car closer to the edge of the car. If its tight than losen it a bit. Quote
