wolfy950 Posted May 10, 2004 Report Posted May 10, 2004 The speedo, gas gauge and even the odometer flicker and flash and then are ok for a while. Sometimes they are out completely. Any suggestions? Quote
Slade901 Posted May 10, 2004 Report Posted May 10, 2004 Re-solder the IC (Integrated Chip) on the digital cluster board. Check my journey when I was fixing my vehicle with the same problem. http://www.geocities.com/southbeach/sands/2476/automobile/digital_instrument_cluster.htm Quote
wolfy950 Posted May 11, 2004 Author Report Posted May 11, 2004 Thanks! That's a great read - your experience. Has anyone else had the same success? Quote
wolfy950 Posted May 19, 2004 Author Report Posted May 19, 2004 Has anyone else solved this problem this way? I looked at my cluster circuit board and It looked fine - nothing was loose. Quote
Slade901 Posted May 20, 2004 Report Posted May 20, 2004 Loose solder on the IC (Integrated Circuit) board is hard to spot. Just re-solder it and see what happens. If that does not fix it then the problem might be something else. Quote
