282 swap
Do cavis and sunfires have the 282? If so, are the mounts the same as the mounts that would be found in a W with a 282? Thanks.
W-bodys are pretty wide in the engine bay and the tranny mounts underneath not from above like J & L -body's. I know that the Beretta's use a different slave cyl/clutch TO fork setup but you may be able to adapt . The intermediate shaft braket will work for sure.
I'm pretty sure that early 90's cavi use the same trans except for the mount but you can bolt on a w-body mount so it don't matter. My flywheel is from a '92 cavi that had the 3.1L and a thrashed clutch and because of it a totaled 282.
