Washer Fluid
Guest RedCutlassSL
Guest RedCutlassSL
My wipers work fine, but no fluid comes out. There is fluid in the container, any ideas?
Simple answer would be fluid pump...
But, obviously you should first check that the hoses are not obstructed in anyway or "gunked up"...
The fluid pump on my Olds Calais went once...
The squirties get plugged easily. If the pump runs, try sticking a tiny needle into the hole of the squirty jet.
and since it is cold where you live did you change the wiper fluid if not could have frozen fuid in the lines just a thought
