Ok, started the car this morning no problem. Go to leave work and nothing. I noticed the lights were dim, So I get a jump and hesitantly it starts, but real weird! About as fast as the solenoid clicked the power seem to flicker, not quite as fast but ...
I get home no problem, All the lights, radio work fine while driving.
I tested the battery and it was fine.
I went to start it and it sounds like wires frying! Lights are dim.
Traced the wires to the solenoid and they are solid, battery connection is solid.
I believe it is the solenoid and not the starter.
What do you think?
Guest Anonymous
Sounds like a good place to start. Got j/y near that you can grab a starter from to try?
Hrmm....sounds like the problem that I am having right now with my 3.4....lemme know what you find out.
My 2k Celica gt-s gets out of the shop tomorrow so I will at least have a ride!
After talking to a neighbor, he also seems to think it is the solenoid, but suggest changing the starter too while it is out. So I am going to do this Sunday or Monday.
how 'bout the ground wires, are they all in good shape making nice clean contacts?
--Dave
I checked the battery with a multi-meter and from that it look good, as did the grounding. So I took out the starter, and battery and took it down to Autozone. They tested the battery which went through the test once and then just quit, after a few more tries it finally came up bad. Tested the starter/selonoid and it cranked fine.
Once I dropped the battery in it started fine.
Cause of the problem was the battery, so I bought a new one ($50)
I have a 96 GP SE w/3.1 and I will tell you what, the starter was easier than the battery to take out!
Thanks for all your help.
Stein
