A/C Recharge...Where?
On the gen2 3.1 motor, where is the valve where you recharge or check the psi of the system? I had my system done this past winter and theres nothing now. Hot air and it sucks. Any help? Thanks...
Look at the A/C compressor itself.
The re-charge port or port where you check the PSI is either located on the compressor itself or tube going into the compressor (they are low side). The low side is where you always check for PSI or charge the A/C system. I do believe that the charge kit connector will only fit on the right charge port (low side) because the other port on the high side is larger.
Anything coming off the compressor and going to the condenser (front of the radiator) is the high side.
