regalized Posted May 4, 2004 Report Posted May 4, 2004 replaced in the last 2 years battery alternater ignition control module plugs/wires twice knock sensor throttle position sensor twice idle air control valve map sensor coolant temp sensor oil pan gasket valve cover gaskets radiator hoses heater hoses heater core water pump serpentine belt that screw ball fitting underneath the collant temp sensor fuel pump front brakes rear brakes rotors calipers, dont we all love when that happens! bottom motor mount torque mounts vacuum line to the tranny modulator valve to the tranny transmission gasket filter changed twice due to gasket leaks and thats all i can think of at the moment now i need wheel bearings tie rods rear struts i need some opinions, keep it and fix it or trade it off thanks Regalized Quote
Brian P Posted May 4, 2004 Report Posted May 4, 2004 as big as that list is, most of it is simple work or looks like you replaced sensors too many times. Any reason for needing the MAP, IAC and TPS changed so many times, or were you trying to find a problem? Also how do you know you NEED wheel bearings? Quote
acke61 Posted May 4, 2004 Report Posted May 4, 2004 i'd say keep it, after doing that much work to it you obviously know that thing inside and out, u go buy a newer car your going to have the same problems except you wont know the car as well...all cars have problems Quote
herb427sc Posted May 4, 2004 Report Posted May 4, 2004 Keep it. At least you do not have a payment book for the next 4 to 7 years!!!!!! Quote
regalized Posted May 4, 2004 Author Report Posted May 4, 2004 i know i need wheel bearings because my front end humms, i know from when my grand prix did the same thing Quote
91oldscutlass Posted May 4, 2004 Report Posted May 4, 2004 Ok you have put this much time and money into it...at least you know what you got there...you can trade it off and get more problems. Quote
Euro Posted May 4, 2004 Report Posted May 4, 2004 yeah i would keep it cause now it should run better with all the things done to it. kinda like mine. heres my recently replaced items 6 fuel injectors(one new one replaced as well) 2 alternators cleaned throttle body, IAC controller cataylic converter battery all hoses fluids replaced and more, i dont have access to my service records, since im at school Quote
GnatGoSplat Posted May 4, 2004 Report Posted May 4, 2004 I would keep it, since it has all new parts, it's like an all new car! Quote
THe_DeTAiL3R Posted May 4, 2004 Report Posted May 4, 2004 My list isn't quite as extensive as that, but its up there! I'm keeping my car till I got money for something I really like, not just trade it in for something thats a little bit better. Besides, trade in value is like $500. If its got a good body and interior, keep it Quote
DaveFromColorado Posted May 4, 2004 Report Posted May 4, 2004 for $90ish you can get your bearing and replace it yourself, it's not that hard on the w-bodies. --Dave. Quote
regalized Posted May 4, 2004 Author Report Posted May 4, 2004 thanks for the input guys, but i have one more question, my motor is loud and i know its from the exaust, when i give it gas it sounds like a tank, could this be exaust manifold gaskets, i have no cat but the exaust is real loud, sounds like i drive a piece of shit :? wait i do lol.....Regalized Quote
