A.R.I Engine Prices
Are these prices way to much are right on the money???
A.R. I. Engines
816-765-4881
GM 60° V6 2.8, 3.1, and 3.4L Pushrod Engine
Stroker Engine & Kit Price List
(Current as of March 1, 2004. Subject to change at any time without notice)
NOTE: These Prices are for 2.8 Engines and Strokers only. Within the GM 60º V6 family, there are interchangeable parts,
but some 3.1L and 3.4L Parts are Different and Need to Be Priced with the application info (i.e. Gasket Sets, Flywheels, etc.!!!)
Basically, beyond the kit or shortblock, we custom build each engine. If you are interested in A.R.I. building the complete longblock for you, the best thing to do is contact us at sales@engine-parts.com. Let us know what you are interested in having done, the type of vehicle you have, transmission type, fuel pump type, and type of fuel delivery system your vehicle has. We will send you an itemized list of the parts you select for your engine plus assembly labor and shipping for your approval. After you approve and we receive payment, you will get your engine in 1-3 weeks (depending on work load and ship time). Use the list below to get an idea of what is available for your engine and then contact us with what you want to do!
*Prices do not include shipping. Shipping cost is usually between $145.00-$175.00 for a shortblock and $225.00-275.00 for a longblock to most of the continental USA. When contacting us, please reference parts by description (and item number if applicable)
The Basic Platform to Build From
Engines & Engine Kits 1 Part #
Price*
GM 2.8L Stock Remanufactured Shortblock
(Less Cam & Timing)NO CORE CHARGE ON THIS SHORTBLOCK $875.00
E-mail
or Call For Purchase
GM 2.8-3.1L Stroker Engine Conversion Kit (need to specify piston size. Available in 020, 030, 040, and 060)(Check availability of 060 before ordering) $495.00
GM 2.8L-3.1L Stroker Engine Conversion Shortblock
(Less Cam & Timing) NO CORE CHARGE ON THIS SHORTBLOCK $1095.00
E-mail
GM 2.8L-3.1L Stroker Engine Conversion Longblock E-mail
Pricing Varies Because each is Custom Built
GM 2.8-3.4 Stroker Engine Converion Shortblock (Less Cam & Timing) NO CORE CHARGE ON THIS SHORTBLOCK $1195.00
E-mail
GM 2.8-3.4 Stroker Engine Converion Longblock E-mail
1 There is NO CORE CHARGE ON THE SHORTBLOCKS. Longblocks have a Core Charge on the Cylinder Heads if Applicable.
*Prices do not include shipping!
Parts Options
Blocks Part #
Price*
2.8 Block for 2.8 or 2.8-3.1, Bored to Piston Specs, Cam Bearings, Freeze Plugs. Available with Purchase of Pistons or Kit from A.R.I. $245.002
Call or E-mail to Order
2 Core Charge of $90.00 for Block if applicable
Camshaft & Lifter Kits (Click here for spec sheet) Part #
Price*
Stock Camshaft & Lifter Kit GMV6-CK00 $122.12
Phase 1 Camshaft & Lifter Kit GMV6-CK01 $138.60
Phase 2 Camshaft & Lifter Kit (MOST POPULAR!) GMV6-CK02 $138.48
Phase 3 Camshaft & Lifter Kit GMV6-CK03 $169.56
Crane CompuCam 2020 Camshaft & Hydraulic Lifter Kit
Special Order Only! GMV6-CK04 $227.75
Crane Compucam 2030 Camshaft & Hydraulic Lifter Kit GMV6-CK05 $227.75
Crane PowerMax F-228/3067-2-12 Camshaft & Mechanical Lifter Kit Special Order Only! GMV6-CK06 $298.79
Crane PowerMax F-248/3334-2-12 Camshaft & Mechanical Lifter Kit Special Order Only! GMV6-CK07 $298.79
Crane PowerMax H-192/2667-2S-12 Camshaft & Hydraulic Lifter Kit Special Order Only! GMV6-CK08 $298.79
Crane PowerMax H-260-2 Camshaft & Hydraulic Lifter Kit GMV6-CK09 $227.75
Crane PowerMax H-272-2 Camshaft & Hydraulic Lifter Kit GMV6-CK10 $298.79
Cylinder Heads & Parts Part #
Price*
Stock Cylinder Heads (Cast Iron, Large Valve) GMV6-CH01 $359.002 / Pair
Performance Cylinder Heads (Cast Iron, Large Valve)
-Stainless Steel Valve Set
-Performance Valve Spring Set
-Performance Alloy Retainer Set
-Performance Valve Keeper Set GMV6-CH02 $565.002 / Pair
Stock 2.8/3.1 Aluminum Cylinder Heads GMV6-CH03 $359.002 / Pair
Performance 2.8/3.1 Aluminum Cylinder Heads
-Machined for and Assembled with the following:
-Performance Valve Keeper Set GMV6-CH04 $595.002 / Pair
Pocket Port & Enlarge/Polish Exhaust Ports for Performance Heads (Great For Stroker Engines!) Labor $350.00
PERFORMANCE HEAD PARTS KIT
Includes: Performance Stainless Steel Valves, Performance Valve Springs, Performance Retainers, and Performance Keepers. The Same Parts we use in our Performance Cylinder Heads!!! $294.95
Performance Stainless Steel Valve Set for 2.8, 3.1, 3.4 pushrod engine Cast Iron Heads GMV6-CH05
$159.95
Stock Valve Set for 2.8, 3.1, 3.4 pushrod engine Cast Iron Heads GMV6-CH06
$129.95
Performance Valve Spring Set for 2.8, 3.1, 3.4 pushrod engine Cast Iron Heads GMV6-CH07
$64.95
Stock Valve Spring Set for 2.8, 3.1, 3.4 pushrod engine Cast Iron Heads GMV6-CH08
$54.95
Performance Valve Spring Retainer Set for 2.8, 3.1, 3.4 pushrod engine Cast Iron Heads GMV6-CH09
$64.95
Stock Valve Spring Retainer Set for 2.8, 3.1, 3.4 pushrod engine Cast Iron Heads GMV6-CH10
$49.95
Performance Keeper Set for 2.8, 3.1, 3.4 pushrod engine Cast Iron Heads GMV6-CH11
$9.95
Stock Keeper Set for 2.8, 3.1, 3.4 pushrod engine Cast Iron Heads GMV6-CH12
$8.95
Performance Stainless Steel Valve Set for 2.8, 3.1, 3.4 pushrod engine Aluminum Heads GMV6-CH05
$159.95
Stock Valve Set for 2.8, 3.1, 3.4 pushrod engine Aluminum Heads GMV6-CH06
$129.95
Performance Valve Spring Set for 2.8, 3.1, 3.4 pushrod engine Aluminum Heads GMV6-CH07
$64.95
Stock Valve Spring Set for 2.8, 3.1, 3.4 pushrod engine Aluminum Heads GMV6-CH08
$54.95
Performance Valve Spring Retainer Set for 2.8, 3.1, 3.4 pushrod engine Aluminum Heads GMV6-CH09
$54.95
Stock Valve Spring Retainer Set for 2.8, 3.1, 3.4 pushrod engine Aluminum Heads GMV6-CH10
$49.95
Performance Keeper Set for 2.8, 3.1, 3.4 pushrod engine Aluminum Heads GMV6-CH11
$9.95
Stock Keeper Set for 2.8, 3.1, 3.4 pushrod engine Aluminum Heads GMV6-CH12
$8.95
Premium Valve Seal Set 2.8, 3.1, 3.4 pushrod engine Aluminum Heads GMV6-CH13
$18.95
2 Core charge on cylinder heads is $45.00 per head if applicable.
Other Items Part #
Price*
Competition Cams Roller Tip Rocker Arms - 1.52:1 Ratio GMV6-RA1 $149.95
Competition Cams Roller Tip Rocker Arms - 1.6:1 Ratio GMV6-RA2 $159.95
Crane Cams Aluminum Full Roller Rocker Arms - 1.52:1 Ratio GMV6-RA3 $382.57
Crane Cams Aluminum Full Roller Rocker Arms - 1.6:1 Ratio GMV6-RA4 $392.57
Stock Rocker Arms ($6.49 each X 12) GMV6-RA5 $77.88
Stock 3-Piece Timing Chain Set GMV6-TC1 $49.95
Double-Roller Timing Chain Set (Note: timing chain dampner may need to be modified for clearancing) GMV6-TC2 $98.00
Timing Chain Dampner $7.95
Performance Push Rod Set GMV6-PR1 $84.95
Stock Push Rod Set GMV6-PR2 $36.95
Stock Oil Pump GMV6-OP1 $54.95
High-Volume Oil Pump (recommended for racing applications only) GMV6-OP2 $79.95
Fel-Pro Complete Gasket Set GMV6-GS1 $115.19
Head Bolt Set GMV6-BT1 $24.76
Harmonic Balancer GMV6-HB1 $59.95
New 1987-88 Fiero Oil Pan (OEM specs) $96.50
New 1985-86 Fiero Oil Pan (OEM specs) $103.75
ARP Rod Bolt Set GMV6-ARP1 $59.95
ARP Main Cap Studs GMV6-ARP2 $88.75
ARP Head Studs GMV6-ARP3 $98.20
FM Water Pump GMV6-WP1 $54.95
Exchange Standard Flywheel, Surfaced & Machined for 2.8L Stroker Conversion ($65.00 core charge if applicable) GMV6-FW1 $105.00
Automatic Flywheel Balanced for 2.8L Stroker Conversion (Note: Jeep Automatic Flywheels are Special Order and $109.95 plus $40.00 to balance) GMV6-FW2 $54.95
Jeep: $149.95
Brass Freeze Plug Kit GMV6-FP1 $8.95
Cam Bearing Set GMV6-CB1 $18.49
Kit & Engine Upgrade Options
Kit & Engine Upgrade Options Part # Price*
Total Seal Gapless Rings for 2.8-3.1L Stroker Conversion
Special Order Only! Price Subject to Change Add $198.74 to cost of Kit or Engine
Performance Chrome or Moly Ring Set for 2.8-3.1 Kit or Engine GMV6-UP1 Add $36.00 to cost of Kit or Engine
Performance Chrome or Moly Ring Set for 2.8-3.4 Kit or Engine GMV6-UP2 Add $36.00 to cost of Shortblock or Longblock
Hypereutectic Piston Upgrade for 2.8-3.1 Kit GMV6-UP3
Add $40.00 to cost of Kit or Engine
Hypereutectic Piston Upgrade for 2.8-3.4 Shortblock or Longblock GMV6-UP4 Add $40.00 to cost of Shortblock or Longblock
NOTE: Forged Pistons are available off-the-shelf for stock 2.8L displacement (plus oversize) engines. For any of our 60-degree V6 Stroker Kits and Engines, the forged pistons are custom made (any design/compression ratio/etc. you want), starting at around $600.00 per set estimated.
Manifold, Carburetor, and TBI Options
Manifold, Carburetor, and TBI Options Part # Price*
Edelbrock Performer 60º V6 Aluminum Manifold Base GMV6-MCT1 $188.98
Edelbrock Performer 2V 60º V6 Aluminum Manifold Top (EGR) GMV6-MCT2 $107.33
Edelbrock Performer 4V 60º V6 Aluminum Manifold Top (non-EGR) GMV6-MCT3 $99.80
Holley 390 CFM 4bbl Carburetor Model 4160 (0-8007) GMV6-MCT4 $350.93
Holley 400 CFM 2bbl TBI (502-3) GMV6-MCT5 $399.95
Holley Square Bore to TBI Flange Adaptor (17-45) GMV6-MCT6 $44.50
Stock 2.8L Displacement Options
Stock 2.8L Displacement Options Part # Price*
TRW Performanced Forged Pistons for 2.8L Engines (Available in 020, 030, 040, 060 oversize) Compression Ratio with stock heads = 8.85-9.1 depending on oversize and heads. GMV6-TRWP1 $329.95
Pro-Builder Cast Piston Set (Available in 020, 030, 040, 060 oversize) GMV6-CV4 $143.88
Moly Ring Set for 2.8L Piston Set GMV6-MR2 $77.90
Cast Ring Set for 2.8L Piston Set GMV6-CR2 $39.78
Special Order Only! $198.74
Reconditioned Connecting Rod (Outright, No Core Required) GMV6-RD1 $18.95 each
Reconditioned 2.8L Crankshaft Kit (Includes Crankshaft, Rod Bearings, Main Bearings. Journal Sizes may be either 010 or 020. Core Charge of $35.00 if Applicable.) GMV6-CKS28 $149.95
Rod Bearing Set (Available in STD, 010, 020, 030) GMV6-28RBRG $27.89
Main Bearing Set (Available in STD, 010, 020, 030) GMV6-28MBRG $39.94
Cam Bearing Set (Available in STD only) GMV6-28CBRG $18.49
Shop Labor Prices & Core Charges
Shop Labor Price*
Assemble Longblock from Shortblock $200.00
Pocket Port & Enlarge/Polish Exhaust Ports for Performance Heads (for Street Performance) $350.00
Computer Balance Rotating Assembly (Using parts from ARI SB assembly or kit) $195.00
2.8 Stroker Engine Balance Standard Transmission Flywheel, Surface, & Install New Ring Gear $105.00
Cross-Drill 2.8L Stock or Stroker Crankshaft $125.00
Core Charges (If Applicable)
Core Charge for Standard Transmission Flywheel - if applicable $65.00
Core Charge for Cylinder Heads (per head, Aluminum or Cast Iron)) $45.00/head
Core Charge for Shortblock $125.00
E-mail sales@engine-parts.com for more information or to order
ARI Engines
816-765-4881
You are aware no one is going to read all that, right?
:lol: you're right i gave up after 5 paragraphs
the Author of the Thread dosen't help ether.... :wink:
what's wrong with CREX? at least he's not a total asshole like some other members here. i know you're probably joking anyways, but i thought i'd add
