camkos10101 Posted December 2, 2002 Report Posted December 2, 2002 how would i increase my fuel milage? there is a shop in town that can do it, but i have no idea how they do....any advise guys? Quote
sx460 Posted December 2, 2002 Report Posted December 2, 2002 They probably clean your fuel injectors, check/replace your air filter, advise in using synthetic motor oil... could be any number of things. Quote
camkos10101 Posted December 2, 2002 Author Report Posted December 2, 2002 i dunno.,... i think that it is more than that...my gf's cavalier got it doen and that 3.1 was getting the milage of a 4 cylinder Quote
90TGP Posted December 2, 2002 Report Posted December 2, 2002 Reduce weight. Take out any unneeded items in your car, cleaning the interior of trash. The less weight you have to move, the better the fuel efficieny and better pick-up you have. Quote
ismellrealbad Posted December 2, 2002 Report Posted December 2, 2002 bad alignment and underinflated tires can give you shitty mileage. give those 2 things some though Quote
Pabz Posted December 3, 2002 Report Posted December 3, 2002 Maybe they just keep your car, and make you walk, thats the best way they can improve your gas mileage. Quote
ismellrealbad Posted December 3, 2002 Report Posted December 3, 2002 can anyone with the 3.1/2.8 actually notice a slight drop in acceleration just by having one passenger or more? also i know this is terrible for the car, but if i started the car after sitting thru a cold day/night, and just floor it and take off right after, it seems much much quicker than any other time. i didnt do that too often but i did notice a diff Quote
badprix Posted December 3, 2002 Report Posted December 3, 2002 yea, the colder the air is and the colder the engine the more power. thats why its best to race when your engine is cold. Quote
ismellrealbad Posted December 3, 2002 Report Posted December 3, 2002 well im talkin about the whole block being a good 32-40 degrees. something that cold i think would hinder performance, let alone the long term damage flooring like that would do Quote
badprix Posted December 3, 2002 Report Posted December 3, 2002 Your right, speaking of cold: I wonder what the stock thermostat temp is for a '89 grand prix. I have the digital guage with analog temp, voltage, tach and the temp stays right at 220 when its warm. I think thats too hot but I love the heater Quote
ismellrealbad Posted December 3, 2002 Report Posted December 3, 2002 thats perfect....i think the thermostat is 190 degrees and in my old prix and this new one they both climb to 220 and sit there and thats it....it should only reach that high if your letting the car warm up for like 30 minutes or if you;ve been idling for a while in general. otherwise it stays around 160 Quote
badprix Posted December 3, 2002 Report Posted December 3, 2002 cool, or should I say hot.......I think I am gonna install a 160 degree stat Quote
Pabz Posted December 3, 2002 Report Posted December 3, 2002 read shawn's take on the issue its in the generic upgrade section http://www.w-body.com/upgrades/engine-thermostat.html Quote
eclipse5302 Posted December 4, 2002 Report Posted December 4, 2002 I agree with Shawn...I had an engine builder show me exactly what happens when you use a colder stat... He pointed to the cylinder wear ridge on the #2 cylinder. That cylinder is right next to the water pump outlet (cold coolant comes in to the block there). There was a HUGE ridge in that cylinder...it caught my fingernail easily. The most pronounced part of the ridge was right behind the coolant inlet! Then he showed me the other 5 cylinders...they had almost no ridge. In fact, the #5 cylinder (farthest away from the coolant inlet) had no ridge what so ever. He said the reason for the large ridge in the #2 cylinder was because of the use of a cooler thermostat. The cooler the cylinders, the more they wear. Of course, I don't listen to my own advice...I use a 160 degree stat in my TurboSTE. But thats because it's chipped. Jason Quote
