GrandPrix34 Posted May 4, 2004 Report Posted May 4, 2004 dont you wonder why it runs better when cold? I do! lol Check the coolant temp sensor wiring harness, sometimes with water and stuff it can and will eat the wires and corrode the harness that plugs into the actual sensor...its a cheap sensor, eassy to replace too. If the injectors tested out fine then save your $$ and look elsewhere. I dont know any other test on injectors other than the OHM testing so maybe you could give that a shot. Hopefully you get her back and rtunning... Quote
slick Posted May 4, 2004 Author Report Posted May 4, 2004 GP34, I'm checking it as soon as i get home today. Quote
slick Posted May 5, 2004 Author Report Posted May 5, 2004 Is this the plug for it? This is located right below the IAC. Just making sure before i start messing with it. Quote
