90TGP Posted April 29, 2004 Report Posted April 29, 2004 Ok, you know the two bolts that hold the rear struts to the strut towers? Does anyone know the size of these bolts? I want to get some bolts to replace those that are just slightly longer in thread length so that I can properly bolt down my rear strut tower brace without having to worry about the thread being too short. I don't want the nuts to vibrate loose and fall off. What is the size of the bolts and where can I get some that are just slightly longer? Quote
Robby1870 Posted April 29, 2004 Report Posted April 29, 2004 I cant remember the size, but Ive had my rear STB on for well over a year, almost two now, and the nuts havent moved at all Quote
Guest TurboSedan Posted April 29, 2004 Report Posted April 29, 2004 take one of the STB nuts with you to the hardware store and find a bolt that is a little longer and that the nut will thread onto no problem. Quote
R Dubya Posted April 29, 2004 Report Posted April 29, 2004 Yeah you want to be cautious of the thread pitch of the bolts when you do that. I think the head of the bolt was 15mm but it's been over a year and I could be wrong. Just don't go trying to put a bolt in with a different thread, make sure they're the same. Quote
acke61 Posted April 29, 2004 Report Posted April 29, 2004 if your going to be buyin bolts at a hardware store make sure they are at least grade 5 bolts, grade 8 would be a good idea....dont want them bastards to break on ya...btw...you can get grade 5 bolts at just about any napa store Quote
no1kicker Posted April 29, 2004 Report Posted April 29, 2004 I believe pep boys has grade 8 bolts. If you can take one there, they have some nuts you can thread into and find the right size and pitch. Quote
