Im trying to get as close as possible on the desktop dyno to get the 3.1.
I have filled in what I know, if it has a ? im not sure, or feel free to correct me. If someone wants 2 post the data on what im missing ill clean up the post and see if we can make it a sticky.
Short Block:
chevy 191 3.1L
Bore:3.503
Stroke: 3.312
Cyl:6 Cyl
Vol:523.1
Total Vol:191.5
Cyl Heads:
Cyl Heads: Low Performance/Stock ports and Valves
Air File:?
Intake Valve:?
Exhaust Valve:?
Compression:
Compression Ratio:8.8:1
Combustion Space: 67.06cc
Induction:
Induction Flow:600.0 cfm @1.50 inHg (??)
Fuel: Gas
Manifold Type: forced induction
Blower: Turbo - Air Research TB301
Intercooler: 50 % (??)
Pressure Ratio: 1.80 (??)
Boost Limit: 8psi
Surge Flow: 105cfm (?)
Eff: 77% (?)
CamShaft:
Camshaft Type:?
Cam File:?
Lifter:?
Cam Spec @:?
Int Lift@valve:?
Exh Lift@valve:?
-Jeff
