It isn't the pressure it's only engine oil pressure, It's the heat. Don't know if they have hoses that will take the heat from the turbine housing. Most all turbos I've seen exit the turbine area with steel or ss and then go to hose. I wouldn't be surprised if the area where the lines screw in reaches 500*. :roll:
You can make them your self from steel brake lines from the parts store and a tubing bender or copper tubing but you would have to flare the copper and use your old nuts. :)
Jud
