DOHC intake gasket replacement
how hard is this to do and what all is needed?
like 3 sockets and a rachet. Maybe some more coolant and the gaskets. It is definately a task that even the a somewhat novice can attempt.
Its a LOT easier on the 3.4 DOHC when compared to the pushrod motors...........there is a nice write up on 60degreeV6.com on how to do it.
Its not hard at all, takes a little bit of time, and is worth it when your done. There were 2 bolts on the lower manifold that were a pain in the ass, and the TB coolant line can also suck. Other than that, its pretty straight forward.
Piece of cake, I did it to both of our motors. Need the above mentioned tools, a universal-type drive for the one bolt by the PS pump is helpful.
Also need about 1/2 case of beer to make the job go smoothly.
If you've never done it before expect to spend the better part of a day doing the job. It starts to get frustrating because just when you think you've got all of the bolts off there's always one more thats a total PIA to get at. A couple tips for ya though;
1. Buy/Borrow a pair of 10" 45 degree bent neele nose pliers it will make the TB coolant line a snap to get off assuming it isn't facing backwards.
2. Get new EGR gaskets, its only a couple extra bucks and you'll save yourself the headache of doing it later.
3. Replace the brake booster vacuum hose as well, its only like $7 from GM and it will save you time later.
4. Make sure you've got a good 10mm socket, a U-joint, and a couple differant extensions (3" and 6" most notably) before you start the project.
alright the last intake i did was on a 305 tbi, wasen't too hard. i was just wondering how this is, i checked the how to at 60*v6, seems easy enough. my brothrs been on my case about fixing his car so it quits ideling high at cold start up. thanks for the advise
