5 speed parts help
http://a5.cpimg.com/image/9F/E4/32576415-ff3b-015600E0-.jpg
i need to know the size of the three bolts that came out of that housing. i also need to know what when in the hole aboe the housing. i assume it is a speed sensor. also if anyone has a speed sensor for that tranny, how much for it. i have parts from a 90 and 93 gp, both se models, if you would want a trade. 90 gp has grey cloth power buckets. oh and also i need the shifter cables if anyone has them.
Malibuolds should know the answer to this, but I'm pretty sure that the hole is the speed sensor hole.
-Tony
that's what i thought. i can't believe the j/y took it out. they also took out those three bolte, cut the shifter cables and took any other hardware i might need. i think i have everything else though
Guest TurboSedan
i'm not sure about the size of the 3 bolts that hold the intermediate shaft in - i'll have to check....
i do have a couple extra speed sensors for the Getrag 282, along with the retainer and the bolt for it. would $10 ok? i will get a pic of that too and try to post them later today.
10 is great. happen to have any extra shifter cables? actually i need a lot of stuff still. pedal, shifter(i'm not sure the one i have from a beretta will work), those three bolts, and speed sensor. but whatever you can spare owuld be fine, thanks.
Guest TurboSedan
i have a couple extra shifters too, one from an '89 Grand Prix and one from an '88 Grand Prix. i'd sell either one for $20 if you end up needing one. sorry i didn't get a chance to get pics today...i will try for tomarrow (have to charge the batteries in the digi-cam)
no problem. i got a shifter. two, actually. i also got cables, but they are from a cavalier. i think they will work(hopefully). i may even have the speed sensor taken care of. i will let you know. now my only problems are the clutch kit and the computer. i called the parts store, and the clutch kit is 288 bucks. the computer is 95 bucks with a 93 dollar core.i have a computer from a 2.8 five speed, but i have the 3.1. the pontiac garage told me it would work, since the last 4 numbers on the coimputer match. what do you think?
Guest TurboSedan
i have a 3.1/5-speed memcal if you need one. this one:
http://www.gmpcm.com/documents/ATMM5331.htm
i guess i would need one of those. what do you want for it. some stuff going up for sale soon. anything you need? i have a 95 gp driver info center plus a few inches of wires. anyhow, let me know how much. thanks again
