CAM TALK
Guest Gp crazy
Guest Gp crazy
WELL I OWN A 1989 GP SE 5 SPEED THE ENGINE I HAD BULIT HAS THIS CAM IN IT MELLING MTC-5 WHICH ====
LIFT GVL .50 SAE DURATION ? WHAT IS THIS ?
I 280 I 420 I 204 I 278
E 295 E 443 E 214 E 288
IS THIS TO MUCH?? WHICH NUMBER AM I WORRIED ABOUT?
THANKS JEFF
IDLE IS A LITTLE ROUGH THAT WHY IM ASKING ?
ALSO UNDER A LOAD UP HILL THE ENGINE WANT'S TO DIE OR CUT OUT AT 3500 RPMS. I THOUGHT THE VACUME WAS TO LOW BUT I HAVE 18 IN AT IDLE. 8)
a performance cam won't have a smooth idle, a smooth idling cam won't make power
you can't have it both ways
what does it do at 3500?
All those numbers mean the following:
intake lift @ valve: .420"
exhaust lift @ valve: .443"
(these are calculated with a 1.5 rocker ratio)
Intake duration @ .050": 204 degrees
Exhaust duration @ .050": 214 degrees
Advertised intake duration: 278 degrees
Advertised exhaust duration: 288 degrees
Intake lift at cam lobe: .280"
Exhaust lift at cam lobe: .295"
Guest Gp crazy
AT 3500 IN 5 GEAR WHICH IS 70 MPH OR BETTER . IT ACT'S LIKE A BAD COIL OR ICM UNSURE ? I HEARD OF FUEL CUT OFF IS THIS TRUE? AM HITTING IT OR EVEN CLOSE TO IT ? GOING TO REPLCE FUEL FILTER AND GO FROM THERE, PSI IS AROUND 38-42. JUST GOING TO ONE THING AT A TIME.
