psykodevul Posted April 17, 2004 Report Posted April 17, 2004 Ok this is the problem i have a grand prix with a 3.1 liter and i was changing out the fuel pressure regulator and while i had the plenum off i sprayed stp throttle body and intake cleaner on the plenum to clean alot of the gunk out. Put the intake on and it started right up and started to smoke and i let it run for about 15 minutes. Kept on smoking so i changed out the new one and put the old one back on and it still smokes. :x What should i do????? :? Quote
joey b Posted April 17, 2004 Report Posted April 17, 2004 probably just that buildup burning or the cleaner itself. Run it for a lil while later and see what you find. Quote
ShockTherapy Posted April 20, 2004 Report Posted April 20, 2004 just crud burning off, the cleaner loosend all the shit in your motor,just get on the high way, and get up on it a few times, should clear out most of that shit. Quote
slick Posted April 20, 2004 Report Posted April 20, 2004 What they said, its stuff probably just burning off. Quote
THe_DeTAiL3R Posted April 20, 2004 Report Posted April 20, 2004 Me too.. when I cleaned my TB the first time it was After if coughed out the junk it ran much better. Quote
