slick Posted April 12, 2004 Report Posted April 12, 2004 Do i just clean the tip of it? Or is there more to it than just that? I have it out right now, so i need an answer soon. Quote
cs916 Posted April 12, 2004 Report Posted April 12, 2004 I've always just sprayed it down with fuel injection cleaner, and used a toothbrush. Be careful not to pull or push on the tip. Then let it dry before you reinstall it. Quote
THe_DeTAiL3R Posted April 12, 2004 Report Posted April 12, 2004 Make sure you get all the gunk out of the spring. I soaked mine in gas :oops: but it didn't break it and seemed to clean it. Quote
GnatGoSplat Posted April 12, 2004 Report Posted April 12, 2004 How clean do you want it? Once I lubed the IAC with white lithium grease in both the 88 and 89. Big mistake, after a couple years, the grease turned to sticky goo. The IAC's were sticking in both cars and both stalling at stops. I pulled out the IAC and with a rubber band, tied a plastic bag around it. Then I kicked on the ignition and the pintle popped completely out. That let me clean out the IAC body, pintle threads, and spring real good. Then I lubed the threads with 5W30 and threaded the pintle in as far as it would go. It's keyed, so it won't go all the way in, but I just turned it as far as it could go with the keyed part in the correct position. Then I loosely installed the IAC into the TB (it won't go all the way in). Then crank the starter for a second or two (it won't start with the IAC like that) and the IAC will suck the pintle back in. Voila! Super clean, and done. I found this procedure to be pretty easy. Also a good rule of thumb is never use any kind of grease, especially white lithium grease, on an IAC! When I used motor oil, the IAC in both cars works perfectly for many years. Quote
slick Posted April 12, 2004 Author Report Posted April 12, 2004 Hmm.... When i have more time, i'll have to take it apart like you did. Quote
