god910 Posted April 9, 2004 Report Posted April 9, 2004 Well, I'm thinking of buying that 4T60E and the 3K stall w/ LSD in the for sale section. I'm just wondering would it be worth it? Do you know anyone that's had an E that would actually hold up? It says 400HP, the LSD is awfully tempting too. I might actually have to have a fast auto TGP as well. Maybe the red one Anyhow, ideas are welcome. Quote
gp90se Posted April 10, 2004 Report Posted April 10, 2004 might have to run another ECU to properly control the 4t60e and u will be trying that tranny pretty hard, keep us updated. -Jeff Quote
GnatGoSplat Posted April 12, 2004 Report Posted April 12, 2004 You would have to run another ECM in parallel. Too much work to program a TGP chip that can control a 4T60-E, I think... you'd have to be a very experienced MC68HC11 assembly programmer to do that. Anyway, adapting a 4T60-E/65-E into an older W-body is on my list of future things to do. A simple microcontroller would only need inputs from TPS and VSS. To control a 65-E would need an additional input from MAP. The rest would be wiring up the microcontroller and MOSFETs to switch the necessary solenoids on and off, and the hardest part is probably writing the program for the micro. Quote
ShockTherapy Posted April 23, 2004 Report Posted April 23, 2004 do it ! a question, when an automatic turbo car upshifts, dose the BOV go off since the throttle plate dosent close ? Quote
god910 Posted April 23, 2004 Author Report Posted April 23, 2004 No, you only get a signal to the BOV when there is manifold vacuum. There is only man. vacuum when the T/Blade closes. But you still get it when you let off, such as after a burnout in the staging lane. 8) Quote
