gp90se Posted April 8, 2004 Report Posted April 8, 2004 Ive been reading old posts and trying to figure out what the best way to go about doing the swap is. I need 2 swap the column anyways, but that wont be here for a few more days. My first question is if anyone has a good detailed write-up on replacing the brake switch and the second, how much harder is it to replace with the column in place? Thanks. -Jeff Quote
Guest TurboSedan Posted April 8, 2004 Report Posted April 8, 2004 Ive been reading old posts and trying to figure out what the best way to go about doing the swap is. I need 2 swap the column anyways, but that wont be here for a few more days. My first question is if anyone has a good detailed write-up on replacing the brake switch and the second, how much harder is it to replace with the column in place? Thanks. -Jeff i thought replacing the brake light switch was a big PITA. i replaced it but had the same problem as before, apparantly i broke the new switch while installing it :? after that i just decided to let the dealership do it for me. at the time tho, i was so sick of working on my car i wanted to strap explosives to it it's been awhile since i've messed with it, but i would think it would be ALOT easier with the column completely out of the way. joshua Quote
