Shaners Posted April 4, 2004 Report Share Posted April 4, 2004 I have a '93 Cutlass Convertible and the center armrest (that is in perfect shape) squeeks like crazy if you have an arm on it. How do you remove it??? I need to fix this annoying problem.... Thnaks Quote Link to comment Share on other sites More sharing options...
Heza Posted April 4, 2004 Report Share Posted April 4, 2004 why not just spray some silicone lubricant on the hinge? Quote Link to comment Share on other sites More sharing options...
NightStalker Posted April 4, 2004 Report Share Posted April 4, 2004 If spraying the hinges don't work, then just unscrew the hinge. If I'm thinking straight, that should be the only thing you gotta do. Quote Link to comment Share on other sites More sharing options...
Shaners Posted April 4, 2004 Author Report Share Posted April 4, 2004 The hinge isn't what is making the noise. It's the actual storage compartment that the hinge is attached to, that is making the noise. It makes the noise where it rubs against the hard plastic center console. That's why I'd like to remove the whole compartment from the plastic console, and either put some foam or some lube on it to keep it from creaking. Quote Link to comment Share on other sites More sharing options...
joey b Posted April 4, 2004 Report Share Posted April 4, 2004 isn't it just held on by the screws in the bottom of the compartment? Maybe from the back of the hinge too. Quote Link to comment Share on other sites More sharing options...
