High Flow Cat For '99 Lumina
Considering that the available aftermarket manifold back exhaust systems for the 1.5Gen Lumina/Monte's are so expensive, I opted to go with a custom setup. My only problem is finding a High Flow Cat that will not trip my check engine light. If anyone knows where I can get my hands on one, gimme a holla. Thanks!!
Jegs sells 02 simulators that can help with that problem
they are ~40-50bux
Search for an OBD-II compliant catalytic converter similar to your stock one(does your Lumina have the o2 sensor placed in the cat or downstream of it?..either way, you can find unversal high-flow cats for the car).
