dbtk2 Posted March 31, 2004 Report Posted March 31, 2004 I have seen posts about the addco swaybar and stuff like that, and I am thinking about upgrading the sway bars on my STE and I'm wondering what I should get for an upgrade and where I can get it. Thanks, Shawn Quote
mfewtrail Posted April 1, 2004 Report Posted April 1, 2004 For the 22mm addco rear sway bar.. http://www.cyberauto.com/index.php/ChevroletLumina.txt listed for a lumina..but same thing. For the front sway bar, I'm not sure what size the TSTE's use? The turbo coupes got the 30mm front swaybar, I believe I've seen 28mm listed for the sedans. Get a 91+ FE3 front sway bar(junkyard or through GM..part # 26024362 price is like $70 or so through GMpartsdirect so junkyard is your best bet or from someone parting out a car on the board.) Quote
Guest TurboSedan Posted April 1, 2004 Report Posted April 1, 2004 i got my 34mm front bar from a '91 DOHC Cutlass coupe. right now i still have the 28mm bar in the car. TGPs got a 30mm front bar i think (?). i've heard installing a front sway bar is a PITA. i'm probably going to install mine after i pull the engine. joshua Quote
mihela816 Posted April 1, 2004 Report Posted April 1, 2004 Performance Suspension Technology also makes a 7/8 rear bar Quote
no1kicker Posted April 1, 2004 Report Posted April 1, 2004 I think there is a 19mm rear bar on the 99ish luminas. Maybe that would fit? Quote
mfewtrail Posted April 1, 2004 Report Posted April 1, 2004 I think there is a 19mm rear bar on the 99ish luminas. Maybe that would fit? I think that's the one Tyroelite on this board just tried that wouldn't work. Quote
