91GranSport Posted November 25, 2002 Report Posted November 25, 2002 If you haven't done so, please check the message I posted earlier titled "Problems With Blower Motor". Anyways, where is the blower motor located on a '91 Regal GS sedan? I'm guessing it should be the same as all other W-Body cars but I still don't know where it is. Quote
Brian P Posted November 25, 2002 Report Posted November 25, 2002 If you remove the black lower passenger dash cover, look under the dash, just behind the firewall, you'll see the blower motor. Might have to remove the "convenience" center to get better access. It's round... Quote
91GranSport Posted November 25, 2002 Author Report Posted November 25, 2002 Thanks for your help Brian, it's good to see that someone actually replies to my messages. I'll give it a shot and let you know how it turns out. Quote
91GranSport Posted November 26, 2002 Author Report Posted November 26, 2002 I'm going to fuck around and try to remove the blower motor tonight. Say, what is the "convenience centre"? I looked at the instructions to replace a blower motor in a Chilton's Guide and it mentioned the same thing you did. I'll probably figure it out when I get around to it but I'll check later on to see if you replied. Quote
Brian P Posted November 26, 2002 Report Posted November 26, 2002 you'll see it. It's a rectangular black block that hold many circuit breakers and some wiring. Quote
91GranSport Posted November 28, 2002 Author Report Posted November 28, 2002 Well, I messed around with it and it turns out my blower motor is fine. I think it's my A/C condenser that is filled with all kinds of shit. My mechanic friend helped me out and it's all back together pretty well. Though it doesn't blow the same amount of air as it used to, it still blows it far better than how it used to. The connectors leading to the blower motor from the fan switch were the main problem, but the condenser itself may be clogged. At least I have airflow again! Thanks! Quote
