sho94_2000 Posted March 30, 2004 Report Posted March 30, 2004 My friends 1994 Olds Cutlass does not start. The security light just flashes. He does not care if his car is protected by PassKey or not. Is there an easy way to disable the whole system? His car is not really worth having it protected and he does not have the money right noy to have it towed and fixed. Is there just a wire he could cut or a fuse he could pull? Thanks Quote
supreme_style21 Posted March 30, 2004 Report Posted March 30, 2004 I don't remember how to disable it.. I think its a series of resistors and whatnot that need to go inline. But pulling fuses and/or cutting wires will just make it worse. It wouldn't be a 'security' system if it was that simple to disable. If he has the chip in the key, try cleaning it. They do occasionally get gummed up and stop working. Quote
MaroonRegal Posted March 30, 2004 Report Posted March 30, 2004 I don't know how to do it, but I bet you have to get it working before you can disable it. Try going to the GM dealer and having them get you a new key. Quote
WhiteOut Posted March 31, 2004 Report Posted March 31, 2004 Don't go to a GM stealership it will run you $30+ for a new key. If your going to go the new key route go to a locksmith you can usually get one cut for around $20. May as well save yourself a couple bucks. Quote
Guest Posted March 31, 2004 Report Posted March 31, 2004 Don't go to a GM stealership it will run you $30+ for a new key. If your going to go the new key route go to a locksmith you can usually get one cut for around $20. May as well save yourself a couple bucks. I doubt a locksmith could get a passkey compatible key...? Quote
loominaz34 Posted March 31, 2004 Report Posted March 31, 2004 Why all the passkey is is a little resistor of a specific resistance (if that makes any sense at all) If the car senses the wrong resistance, the car dont start. Quote
