turn signals don't blink
My turn signals light up, but they don't blink. I checked the fuse, but that wasn't it. I think it is the turn signal flasher unit. It is connected to the steering column bracket, but I can't get the panel covering it off. The screws just keep turning, but they are not stripped. How do I get these out?
If the screws just keep turning, grab 'em with a pliers and yank them out.. Unless it is held up with those stupid black plastic things.. break them and go buy some new ones when you put the panel back up.
But it sounds either like a flasher, or a bulb is out somewhere.
my vote is for a bulb, mine did the same thing till i replaced a taillight bulb
how often do two bulbs go bad at the exact same time??? :roll:
Yea that panel underneath is held in with those plastic black things. But I'll check all the bulbs first, because it might be one of the taillights.
I hate those plastic things with a passion. The quickest way is to just bust them. I can always get them at a parts store for cheap to replace.
see, my car is doing that too. when i use the signal for merging left, it just stays lit up. i noticed both sidemarker bulbs up front were out, so i replaced the driver side and am awaiting a bulb socket for the passenger side since it was fried. hopefully that fixes the problem. it got my hazards working though!
