GrandPrix34 Posted March 25, 2004 Report Posted March 25, 2004 What are the symptoms of a fualty crank sensor? Right now I have several issues with the car as you can see through my other post. I have a vacuum gauge and it reads normal vacuum...sometimes it will start dropping to the point where the vacuum reads late ign. timing...i already replaced the wires wit the 8mm taylor wires and that correct the idle some but i still get some stalling to where it dies sometimes. I OHMed check the fuel injectors all read 12.XX. The pluges/wires are new...the ign. module is also fairly new. ECM is also replaced wit a newer one. I know what a bad coil feels like so Im narrowing it down to the crank sensor.... What do you guys think? Quote
4spdz34 Posted March 26, 2004 Report Posted March 26, 2004 check the wiring for the crank sensor and, late timing could also be a knock that the knock sensor is picking up but u can't hear Quote
regalized Posted March 26, 2004 Report Posted March 26, 2004 when my crankshaft position sensor went out, the car would go dead without warning and wouldnt start up for about 30 minutes then one day it would just roll over but wouldnt fire...regalized Quote
DaveFromColorado Posted March 29, 2004 Report Posted March 29, 2004 a lot of times a falling vacuum gauage can also mean pluged exhaust, if all the exhaust can't get out of the cylinders, you can't expect it to draw much vacuum. --Dave Quote
