Jon89le Posted March 23, 2004 Report Posted March 23, 2004 I took my heads off, the front one in particular, and i realize that the bottom head bolt holes have coolant in them. Then i put my finger in the coolant passage and notice that the bottom of the bolt holes are hollow. This normal? Quote
Intimidatorz34 Posted March 23, 2004 Report Posted March 23, 2004 are you sure coolant didnt spill in there when the heads came off? Id be willling to bet that is what happened. Make sure to dry them up before you reassemble Quote
Jon89le Posted March 23, 2004 Author Report Posted March 23, 2004 Nah bro, like i said, i put my finger inside the coolant passage and touched the underneath the bolt hole and saw my finger through the coolant. All of the front bottom head bolts are like that. Quote
Slade901 Posted March 23, 2004 Report Posted March 23, 2004 hmm... interesting. So, I guess if I have to do mine I'd better coat the threads with some gasket sealant or some RTV to prevent coolant from coming up through the bolts. Quote
Jon89le Posted March 23, 2004 Author Report Posted March 23, 2004 When i pulled my rear head bolts i noticed like a sludgy residue on the bolts, but only some were like that, the bottom ones. I guess that was due to the Anti-Seize mixing with the coolant. I just find it wierd. Quote
GnatGoSplat Posted March 23, 2004 Report Posted March 23, 2004 Yeah, it's normal. Some of them you're supposed to use a teflon thread sealant. Quote
