Hey All!
My mom's 1993 Regal has a little problem. When you switch on the highbeams, they immediatley switch back to the low beams. I discovered this when the had a headlight out, so I checked the wiring and got the headlight to work again, but noticed this.
Is this a sign of a bad bulb? Has anyone else had this problem? I have exactly zero experience with composite headlights.
Thanks alot!
Hey All!
Thanks alot!
Its the high/low switch that is located in the steering column. Had this problem on one of my other cars. It can be a pain to replace. You drop the steering column, but dont have to remove it. you will see a rod on the left top side. that goes to a box which is the switch. Not sure where you can get it from, i know they are out there thou...
