GRANDFURY Posted March 22, 2004 Report Posted March 22, 2004 I keep getting a code 32 for egr but i have no vaccuum leaks and the diaprahm works good any other thoughts. Car is a 89 GP le with 2.8 auto. Thanx. Quote
Slade901 Posted March 22, 2004 Report Posted March 22, 2004 Try taking off the EGR and clean it and clean the passage ways going to the Throttle Body and the other passages in the exhaust. I'm sure the passage ways are gunked up. Install back the EGR and remove the battery cable to reset the computer code for at least 15 minutes and reconnect the battery and test it. Quote
rudefyet Posted March 22, 2004 Report Posted March 22, 2004 check fuses....and make sure your battery is charging a messed up Ignition fuse caused my car to throw an EGR code Quote
